Wifi Performance on VU+ Solo2
  • reloaded
    • Apr 2009
    • 225
    I've just bought a solo2 and installed latest blackhole image,
    after getting almost everything to work I realised the USB wifi stick does not work as well as it works on my dm800hd gemini image?
    The performance is terrible, it cuts off most times and when streaming video online lags all the time...
    I'm really disappointed that I spent ?300 on it hoping it will improve on the dm800hd clone, but I think i was wrong...
    I've tried 3 different USB wifi sticks all get recognized straight away, but with terrible performance, I'm desperate for this to work as I cannot afford to go through the wired option.
    any help would be much appreciated as always.
    New Season...New hope! YNWA.
  • cactikid
    • 12017
    on the other place i saw this issue with the dongles.
    I've seen many reports of users having trouble with WIFI dongles. We're tried and tested the Tenda W150M with the Duo, Solo and ET-9000 and it works spot on. Can be ordered here **********
    This is a WiFi Bridge NOT a USB WiFi Dongle. Its an alternative for anyone having trouble with USB WiFi Dongles.
    handy to know at times.thanks ***
    Last edited by satsmo; 5 January, 2013, 02:11. Reason: Removed link to forum of similar content
    • reloaded
      • Apr 2009
      • 225
      Cheers for that Woz, by the way it took me an hour to download a Blackhole skin through the wifi connection!
      appalling!
      • cactikid
        • 12017
        bloody link dont work ,i saw this on their site.
        VU+ WIFI N 300MBPS USB DONGLE FOR DUO SOLO UNO ULTIMO
        they have their own dongle now.
        • satsmo
          • 6397
          And we have our own forum.
          • cactikid
            • 12017
            sorry satsmo,i just meant they have their own brand of vu dongles as maybe the usual ones cannot cope.
            • pongo snodgrass
              • 178
              use homeplugs...much better, i use the tp link 200Mbps ones, rock solid connection
              • reloaded
                • Apr 2009
                • 225
                Pongo, i have a 3 floor house, how would i know if my power runs through 1 main ring or 3 defferent ones?
                or else I would have would bought this as first choice!
                they wont work if its 3 different rings right? Arent the 3 rings supposed to be connected?
                • freck
                  • 1076
                  Test out your rings....plug a few lamps in on the socket your homeplugs are gonna be.
                  Hit the switch on your mains circuits and if both lamps go off then theyre on the same loop...if one stays on then go for the tenda option.simples
                  Freck
                  • cunny
                    • 4915
                    Just curious as to why you can't run a cat5 cable to it?
                    Sent from my GT-I9300 using Tapatalk 2
                    • dell_xps
                      • 2558
                      I have the Vu dongle got it with my Ultimo, ?30 to buy, also have comtrend home plugs, I would suggest you go with the home plugs m8, rock solid on HD channels, whereas the Vu dongle tends to lag/break up on HD content.
                      You'll get the comtrend plugs on Ebay, should get a new pair for ?30 to ?40, these ones you can plug a socket into them so you still have a socket to use :-)
                      HTH
                      PS As Cunny suggest you can't beat using an ethernet cable, rock solid connection and it's cheap as chips for the cable.
                      • reloaded
                        • Apr 2009
                        • 225
                        Hi Everyone,
                        After trying a few USB wifi sticks I decided to give up and go for the Power-line Ethernet option, and I must say the improvement is head
                        and shoulders above any wireless connection, I even went for the official VU+ stick, and that was terrible too.
                        I cannot recommend the power-line option high enough, it has saved me many headaches and the connection is superb!
                        for those wondering what brand I went for, it was the Netgear 200mbps Nano kit, as I was desperate I grabbed it from Currys
                        just to see if it works, ended up paying ?39.99.
                        Thanks to everyone who posted to help.
