solo and Router problem
  • liam1982
    • 37
    trying to access my solo using DCC to add cline, but the router says solos ip is 0.6 and the solo says ip is 0.8 tried everything just cant get them to match so i can edit my cline...any info much appreciated...thanks
  • wilf
    • 1618
    in network settings on solo have you tried to disable dhcp and set your own ip then you will know exactly what to enter on dcc
    • liam1982
      • 37
      thanks for the reply can you be a bit more specific please,would that be menu>network>device set up>adapter settings>user dhcp>no...then what
      • septicsmurf
        • Feb 2012
        • 401
        Then enter the ip address you want it to be.
        • liam1982
          • 37
          managed to set box same ip as router using DCC connected>ftp>etc>no cccam.fig to add cline? anyone any ideas how to fix...thanks in advance
          • BigfatPaulie
            • Dec 2011
            • 203
            If it's same ip as router you will have problems...
            Each device on your network has to be unique... ie the last 3 digits HAVE to be different on every device... By far the easiest way to ensure this is to use dchp on ONE device only - usually the router, this will issue ip addresses automatically to each device.
            You don't need to turn dchp off to assign a fixed address to your box, just turn the router off/on after setting up your box to ensure its unique... My solo is set to 192.168.2.110 makes it easy to find in dcc!
            Sent using Tapatalk
            • liam1982
              • 37
              worded that wrong i meant i manually changed the ip on the box to the same as my router assigned it ..0.3
              • simon 2003
                • 27
                have you tried rebooting your router mate,as the dhcp scope should allocate it a seperate ip with no problems
                ok so you have given it .03 is DCC giving you a green line from router to solo to pc ?
                or if i havent read right you have sorted that bit and cannot find your .cfg,im presuming you have a cccam installed,some dont install a cfg , if you find one add your line to line 80 remove hash first,or just delete the whole lot and put your line in
                • liam1982
                  • 37
                  thanks simon that sorted it mate...cheers
