VU+ Solo Hard Drive Setup
  • mickb82
    • Jan 2013
    • 35
    Hi,
    I have just ordered a VU+ Solo and I want to be able to record to an external hard drive.
    I have been reading several forums and it seems like most people recommenrd externally powering the hard drive to avoid strain on the VU box's power supply.
    I already have a 250GB 2.5" SATA hard drive in an enclosure with a usb Y cable that can be plugged into 2 USB ports for extra power, If I plug the main usb into the VU box and the other usb into a USB mains AC adaptor would this work or would I risk damaging the VU box?
    The adpter is HTC AC to USB adpter and the output is 5v 1A.
    Mick
  • cactikid
    • 12017
    i believe you can use the internal hdd and exterior hdd but i would advise to have a powered one to plug into the mains and just use the 1 usb port
    • septicsmurf
      • Feb 2012
      • 401
      Is it a clone or original solo?
      I know clones have a lot of psu trouble from experience.
      • mickb82
        • Jan 2013
        • 35
        Thanks, it's a clone. After more reading I have decided to buy a mains powered USB hub, it's not worth risking damaging the box when I can get a hub for ?6! I will then plug the HDD into this. Also with a hub I can plug in an additional USB stick for epg, channel icons and pausing etc without it sticking out of the front.
        Thanks.
        • Deejaygav79
          • Nov 2013
          Hi just wondering if the usb hub worked for you. I have a external HDD and want to use it along with a usb pen drive but was wondering if both will work through the one USB port.
