delete chanells
  • coolhas
    • 38
    delete chanells
    hi i have got a problem that's doing my head in im trying to get a channel list that is sorted out by me but when i upload the channel list via dream box edit im just getting duplicates etc
    is there any way where i can just delete all the channels i have and start from fresh because i still haev some channels that just wont remove from the iniital first scan using latest vix image vu solo
    also some times when i use the zap back to last channel button i get the tuner failed message if this helps
  • digicon
    • 8261
    When you re-uploaded the channel list did you do a reset enigma on your box for the changes to take effect
    • coolhas
      • 38
      hi yes did a full reset
      • DOUGALMCD
        • May 2011
        • 3229
        Underneath the send files to dreambox make sure you tick remove unused bouquets from dreambox. hth
        • coolhas
          • 38
          done that to seems it doesn't remove old channels thanks for replys
          • digicon
            • 8261
            If that has not worked then FTP into the box and goto /etc/enigma2 and delete all the channel list data out of there and try again
