2 Vu Solo's with same Mac Address ? conflict
  • lombard
    • 793
    Hi, all i have 2 Vu Solo clones which take latest images, both flashed very latest build of vix 3.0 from official site and work very well, but cant connect at same time cause they have same mac address ? is there anyway i can connect both ? or change mac address of one of the boxes ?
  • cactikid
    • 12017
    menu- system-network-adapter settings-use dhcp-change ip address to one not used,or powering off box can give it a new ip but could clash at a latter stage.
    giving a box its own ip less chance of a clash then.
    • lombard
      • 793
      tried that didnt work, its the mac address i think i need to change in order for the router to let both connect !
      • cactikid
        • 12017
        sorry reread your first post again,if its to do with them things we cant talk about?
        • lombard
          • 793
          Hi all i want is to connect both to same local network, use plugins etc , can as both boxes macs are the same
            seems strange that both of the NIC's have the same MAC address this is something you usually see on clones and not on originals, As far as i am aware the MAC address cant be changed via any of the standard ways, but someone may know a way around it.
            • BigfatPaulie
              • Dec 2011
              • 203
              How the hell can they have the same MAC addresses?
              Sent using Tapatalk
              • RuberDuck
                • 1724
                They are clones mate.
                Sent using Tapatalk
                Simply because they are clones.
                • BigfatPaulie
                  • Dec 2011
                  • 203
                  Seen many a clone, never had this!
                  Sent using Tapatalk
                    Sent using Tapatalk
                    LOL i should read more carefully as well, thats the main problem with Clones not only is the Box cloned so is all the serials and relevant data such as MAC address, i have seen 3 solo clones all had the same data as i described, Thats one of the bug bears i suppose
                    • cactikid
                      • 12017
                      so dont go and buy loads of boxes for your home aas only 1 may work at a time,now thats a good reason to buy and original or 3.
                      • lombard
                        • 793
                        sorted it , went into router and let it relocate IP and both work fine now
                        • cactikid
                          • 12017
                          must have been an ip conflict and not a mac conflict? good its working.
                          • lombard
                            • 793
                            Hi, no the mac address are same on the boxes, had to go into router firmware to get both working
