auto bouqets
  • coolhas
    • 38
    auto bouqets
    hi i want to download the latest black hole image any idea where i can find them i know where to get the vix but cant seem to find the black hole
    also would any one help me setting up auto bouquets on the black hole image maybe a mini guide or something please
  • LraiZer
    • 126
    Black Hole images have a corrupt 28.2E satellite.xml that makes the 28.2E services greyed out and void when using autobouquets.
    to fix this you will need to first edit the satellites.xml file in Black Hole image, to make sure the 28.2E sat position is correct one.
    if position="284" as below, then you must first edit this to read postion="282" instead.
    <sat name="Astra 2A/2B/2D/Eurobird 1 (28.2E)" flags="0" position="284">
    <sat name="Astra 2A/2B/2D/Eurobird 1 (28.2E)" flags="0" position="282">
    then you need to reboot box and reconfigure tuner back to astra 28.2e again so that box scans position 282 and not 284.
    you can then safely install the AutoBouquets E2 28.2E .ipk package and it should work the same as any other none corrupt satellites.xml.
