Adding biss keys
  • DARRENHGV
    • Jun 2009
    • 14
    Adding biss keys
    use to add biss keys to my old tecnomate 1500ci but that was some time ago and i have not got a clue how to enter them im running blackhole 2.02 and cccam could someone tell me how i go about doing it ..........................key.
    You will need MGcamd 1.38 installed on your receiver and then just add the Softcam.key file to /use/keys and activate the cam some need MGcamd others will run with CCcam
    By the way please do not post Keys in plain sight either in a .txt format or inside a folder thank you
    • DARRENHGV
      • Jun 2009
      • 14
      I have added Mgcamd gone to the ts panel and started it added softkey still no joy.
      if i press blue button it says 2 cams installed oscam/cccam which i have always had can not see mgcamd.
        If running blackhole you should have got Mgcamd from one of the previous discussion threads instead of letting TSpanel install it as sometimes i have noticed it cocks up on some images.
        Download from my post here: http://www.digital-kaos.co.uk/forums...3/#post1928336
        Extract the .ipk to /tmp folder and do a manual install via the menu
        Job done
        • Cageyone
          • 4
          I'm having problem with TSpanel. When I install via VUcc/FTP it says under the black panel that it is"installed; but in the black panel it shows "Collected errors: Already provided by package. The "enigma2-plugin-extensions-tspanel_**_mips32el.ipk" does show in the var/volatile/temp file, but the TSpanel does not show in the Green Panel. Can you help please
