help please iv tried to restore to an early point and when I did it came up reflashing solo please wait and the power cut out while that was up and when I powerd back on theres a green light on box but nothing comes on cant even see it in my input on tv
vu is not workin
As long as you have power you should be OK to re-flash the box again from Scratch as you did before, Worst case scenario is the powercut may have damaged the nandflash where the image is stored when flashed if that has happened the box is goosed.
But first try flashing Via USB and if that does not work then maybe try using Null modem cable and the official software
no nothing is coming up on screen and cant see it in my input on tv its just the same as before, i power the box down insert usb turn on and led is red for a 10th of a second then green and stays that way power botton on remote does nothing either its just staying green led it wont reflashComment
It looks like you may have to try and flash this Via the RS232 port on the back of the box with a Null modem Lead
Official firmware can be found here: Archive of Vu+ you want the Vu Solo .nfi file
The RS232 Program can be found here: http://www.digital-kaos.co.uk/forums...-0-1-a-217163/
got the tool what image do I use is it he top 1 vuplus-image-bm750-20120203012328.nfi
No as i stated the one that says Vu Solo the one you quoted is for the Duo (bm-750)
A quick search brought up this guide in a post here for the Clones but is identical for originals download the guide on how to update via RS232: http://www.digital-kaos.co.uk/forums...ml#post1642559
