old vu solo original issue
  • cactikid
    • 12017
    starting from scratch with new install of latest vix i run into a syntax error while trying to install ipk file,having used image and mg camd
    from vix,any suggestions and no i dont use cccam.cheers
  • digicon
    • 8261
    I assume you used telnet to install the .ipk as for the error could be the .ipk file did you get the official Vix cams from the usual download place: OpenViX Downloads
    • cactikid
      • 12017
      yes files from there but i used filezilla,not used telnet before,not used many things before
      • digicon
        • 8261
        If your still getting the error doing it manually from the /tmp folder using the built in installer you could try using Telent and install it that way instead using this command: ipkg install /tmp/insertpackagename.ipk
        • cactikid
          • 12017
          yes still getting it,even others with remote access hit the brick wall ,might give that a go tomorrow cheers.
          • cactikid
            • 12017
            still hit the brick wall with the lappy ,but i used a desktop pc and w.7 and tried again ,went straight in ,strange as they all have same anti virus.
