motor probs
  • shaunfree
    • 358
    motor probs
    Hi all,could anybody please help me with motor setup on a vu+solo at the mo using usuals which is all good on most sats,but on the harder sats to get,i get very low signals so would like to be able to step the dish east to west to get the best signal i can, so my aim is to use usuals+Diseqc 1.2 together but can not figure out how to,looked all over the net but can only find guides with how to setup with usuals and guides to setup Diseqc 1.2 not both together cheers shaun
  • digicon
    • 8261
    you will have to setup the tuner side to advanced instead of simple so on every sat if you want to use USALS you scroll to the very end and have an option that says 'Use USALS for this sat' choose this for the USALS ones and the ones you wnat to fine tune select No and then the Diseqc 1.2 option appears and you assign the satellite you fine tunes a number, You have to do this for every satellite
    • shaunfree
      • 358
      Thakyou again digicon was really stuck here,when i store a sat,can i store it as any number, thanks for your time mate,cheers shaun
      • digicon
        • 8261
        Any number you wish just remember the only sats you will store with 1.2 are the ones that will need a number the rest can just use USALS and no number required
        • shaunfree
          • 358
          Thanks again digicon,all a bit clearer now cheers shaun
