vu+ solo box
  • broxiblue
    • Apr 2014
    • 9
    vu+ solo box
    hi ppl, can anyone help me on a few questions bout a vu+ solo box?
    Q1. how can i configure my external hard drive to my vu box?
    Q2. i have it formatted to ext4 but when i plug it in my laptop , it says that i have to reformat it again, can anyone help me on this?
    thanks.
  • broxiblue
    • Apr 2014
    • 9
    I MUST BE INVISIBLE
    • cactikid
      • 12017
      do you have it mounted also in mount manager? hopefully you are using a powered usb supply and hardrive is no bigger than 1tb.
      • shaunfree
        • 358
        Have a look here mate VU+ SOLO external HDD setup.txt cheers shaun
        • broxiblue
          • Apr 2014
          • 9
          hi shaun, thanks for replying i have a 500gb seagate external hard drive which plugs into the back of my box. what happens if i want to say put a film on my hard drive and watch it on the solo box, will it pick it up in ts media? thanks
          • shaunfree
            • 358
            Hi broxiblue as cactikid said have u got external power to HDD,and have u mounted the drive with mount manager and restarted,if all ok and mounted should work 4 recordings and timeshift once setup correctly,cheers shaun
            • shaunfree
              • 358
              once u put film on hardrive press button next to menu and your recordings plus any films u added will be listed on your hdd cheers shaun
              • cactikid
                • 12017
                ditto ,tsmedia is via lan if you want other things.
                • broxiblue
                  • Apr 2014
                  • 9
                  yeah it plugged in via a usb port, how do i sort out timeshift settings? my hard drive is formatted to ext4, but if i plug it in to my laptop, and want to add films , it wont let me cause it says i have to formatt the h.d. thanks
                  • cactikid
                    • 12017
                    you dont remove usb but there is a way to ftp films from pc to box not used it,samba.
                    • broxiblue
                      • Apr 2014
                      • 9
                      i have another wee question to ask, how can i get the epg downloader to transfer to the hard drive instead of the internal memory, and can i delete the cacheflush? thanks
                      • cactikid
                        • 12017
                        you would need to change where epg is stored and not internal flash or you will end up reflashing unit.
                        cacheflush is in plugins from the menu you download and it maybe be an extension ,not used it so unsure where.
