Any Brand should do the trick as its 2.5" form factor there is no worry about Heat so what ever you can afford will do.
i have seen a 2.5 inch hdd but it says its 7200 rpm instead of the normal 5400 rpms and a 32mb cache instead of normal 8, would this be any better than the normal 2.5 hdd
All 2.5" dives run cool no matter if they are 7200 or 5400 spin speed, People get confused with this on the standard 3.5" drives that you find in Computers and $ly Hd Receivers they use a 5400rpm speed due to the size it generates more heat so the slower spin speed keeps the heat down and thats why on 3.5" you would chose a 5400 over a 7200.
It wont matter a Jot what spin speed you get 5400 or 7200 it will run cooler than a standard 3.5" drive, Also more Cache is better makes for a faster drive
