Vu Solo2 Changing channels from one to another channel the screen picture remains
  • DAVHAY77
    • Dec 2010
    • 7
    Changing channels from one to another channel the screen picture remains the same,
    so if I carry on changing channels and if I cannot find a free channel the screen picture does not change.
    I have restored to factory setting but it has not changed.
    I hope this makes sense.
    Please can someone Help.
  • ontherack
    • Apr 2011
    • 1080
    clone or not
    image used
    reflash
    use image backup
    • benny/9
      • 1964
      it's a image problem and if it's some time
      since you changed it then going for the latest
      image will give you all the latest drivers etc:
      just remember to upload your channel list,
      config file. settings file from the box to your
      computer first then after flashing you will have
      the box up and running very quickly and wont need to
      re-set up all your personnel setting again
      Please Read Carefully!
      • cactikid
        • 12017
        if using vix do not use restore settings as they like a fresh install with no backups used.
        • DAVHAY77
          • Dec 2010
          • 7
          Thank you for Helping me.
          I will try to flash it with a bit of confidence.
          I will try to find the image file.
          Thank you once again.
          • DAVHAY77
            • Dec 2010
            • 7
            I get frozen images when changing channels, until I find a free channel.
            Things I did and one of them was messing about with the webif and the recording light was on but not recording, but it OK now.
            so do you think I can delete the webif or is it gong to cause a problem ?.
            I would like to Thank you all for helping me.
            • cactikid
              • 12017
              red flashing light maybe is unstable update whereas green means safe update.is your box hard wired to lan and not wifi? have to be carefull whats said due to forum rules.exit out of webif.
              • DAVHAY77
                • Dec 2010
                • 7
                I will keep well away from webif.
                Thanks for your Help.
