vusolo2 NAND replacement question
  • loncell
    • 625
    If you replace the TSOP-48 in a vusolo2 does it have to be the identical TSOP48 make/model No or can you use different type ?
  • suttsy
    • Jun 2013
    • 31
    If your referring to the flash I/C chip, then yes.
    However, if your box is a clone then you'll be doing well to get that chip, as it appears they are no longer available from the supplier.
