Solo2 Sunray Hangs After Booting
  • wurz
    • Apr 2010
    • 123
    I have a couple of Sunray Solo2 boxes suffering from the same issue and no matter what image I flash the issue remains. They are taking the image and booting, but after about 5 seconds the boxes simply hang. The screen freezes and becomes totally unresponsive.
    I could be wrong but I don't think this is related to the flash chip as the box will flash and then boot. The issue occurs after booting.
    I've searched on here and on google but haven't found anyone else with similar issues but I'm wondering if anyone else has come across this and if there is a fix?
  • shaunfree
    • 358
    not sure but try factory reset then reflash hope it helps cheers shaun
    • wurz
      • Apr 2010
      • 123
      I've flashed these a few times, I don't think this is software related because it occurs with different images.
      • shaunfree
        • 358
        yes but try factory reset first have you tried that way before you reflash cheers shaun
        • DOUGALMCD
          • May 2011
          • 3229
          Have you any other usb connected when you flash? If so remove them. When you flash is box extra hot and is fan working? Are psu on boxes ok?
          • wurz
            • Apr 2010
            • 123
            Issue remains, sorry for very late reply
            To answer your questions, no other USB pens are connected
            and
            Fan is working and box seems to be running at normal temp.
            • DOUGALMCD
              • May 2011
              • 3229
              Sounds like the the box doesn't want to boot the image as the image may damage the box ie a clone measure to stop the box bricking. What image did you have on them before and do they still work on box are you loading clean image without settings back up etc. What make ie lonrisun and version of sunray are you using as this will help others help you. hth
