Results 1 to 4 of 4
Threaded View
    May 2017
    Default MB Sprinter 316 2010 2200 163HP CDI Delphi CRD2 mpc556 need dpf off
    I need tested solution DPF off for MB Sprinter 316 2010 year 2200 163HP CDI with ecu Delphi CRD2 mpc556. In attached read file with Flex obd mode.
    I have tested ori DaVinci Deluxe solution but after flash back mod file on dashboard I have blinking check engine lamp. When I check dtc with diagnostic tool - Launch - as Mercedes Sprinter there are no dtcs in engine module, but if I do scan with normal eobd mode I Have got dtc P0000 - and I can not clear it.
