Results 1 to 3 of 3
    Bllinda's Avatar
    Baltic
    Post Opel EDC16-C9 remove EGR and DPF
    Hi guys,
    I need your advice or solution, help to disable, delete DPF and EGR. Thanks
    DTC-P1902/05,P0180/04,P0400,P0070/71.
    I am attaching the original file read through BDMxxx-0281011669
    The symptoms are the same
    https://www.digital-kaos.co.uk/forums/showthread.php/218106-EGR-OFF-and-DPF-OFF-Opel-Zafira-B-Z19DT?p=1187641&viewfull=1#post1187641
    And in the final there is the Limp-mode mode, engine speed 2200-3100 rpm.
    today
    A topic that interests me
    Jan 2020
    egr dpf off.
  3. The Following User Says Thank You to PDXAutoworks For This Useful Post:
    Bllinda (21st July, 2023)
    Bllinda's Avatar
    Baltic
    Sorry. And this solution is not working. Te2ch shows the same message.
    Your help is needed.
    today
