Results 1 to 12 of 12
Hybrid View
    Oct 2008
    Default Starview HD combo plus with LAN
    Just tried loading the updated firmware for this box and I keep getting update failed at 20% please check memory. My memory stick looks fine as i have used it recently and I have also tried another one which I formatted and still get the same message. Can anyone help ????
    Jul 2009
    Are you sure you are putting the "with LAN" software on a box with an ethernet socket on the back? If no ethernet socket, you should use the "non LAN" version of software. I had the same situation when trying to put non Lan on a Lan box.
    Oct 2008
    Pretty sure my box has a LAN port and a serial port
    Oct 2008
    Have got the right firmware but still get message update failed check usb memory, I have tried various usb sticks but all do th same any help would be appreciated cant be the only one with this problem....
    Jan 2009
    Quote Originally Posted by Bert50 View Post
    the best way to do it is format usb in combo, rather than pc, then put software on stick and try again.
    Oct 2008
    Did what you said formatted the usb stick and downloaded the file straight onto the stick and it still comes up with update failed check memory......
    Jan 2009
    did you format in starview or pc.
    Oct 2008
    Thanks for your help but I now have it working, the problem was not the usb stick, what I did was I updated the software using an older firmware package (from Dec) and this worked ok and then I updated using the lastest firmware. All is fine now so if anybody gets the same problem use an older firmware first and then it will update with new firmware releases.. thanks again for all your imput..
    Aug 2009
    can you tell me how fast is blind scan on this box?
    for example ..
    10950-11200
    11450-11700 Areas
    how sensitive is the tuner?
    He is the blind scan the SR 1000.1333 .. ?
    how much does the minute to auto-scan?
    I find pictures anywhere on the Receiver.also menu, OSD images. Blind scan images menu
    Nov 2009
    hi can you plz help me how to starvew hd non box softwere download
  11. #11
    May 2010
    I have jusy picked up a starview hd combo with lan (rs232 and ethernet connection at back) and need some help with firmware.....What is it and where do I get it from and how to install.....Please help if you can...
  12. #12
    satsmo's Avatar
    Jun 2008
