Results 1 to 10 of 10
    Oct 2008
    Default newbi back at last
    hello all
    I have now got a full system working after 4 weeks of toil, had to move dish to peak of house, reset at least 4 times the pole set up found thor only got 2 transponders , etc, etc many hours in rain wasted, Eventually got a old boy who was a radio ham and sat guru to come round , climb up to dish with a antique meter, diagnosed issue with lnb only working in vertical , new one fitted, reset complete arc bobs your uncle, system is now up and running, just carrying out auto scan for channels as i am sat writing this,
    whats next !!
    Technomate 6800 hd
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    glad to know ur sorted now after all those pm`s.
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    Administrator
    Devilfish's Avatar
    Feb 2008
    All part of the fun hehe.
    Next - have you flashed the latest patch for your receiver so that you can get the hacked channels? See the sticky threads.
    Nov 2008
    i'm a noob who's back too but I can't seem to download anything yet
    Oct 2008
    oop's just down loaded a channel list and lost all positions of satellites, which are the best satellites for sport and nature programs
    Aug 2008
    var/tuxbox/plugins
    Goto usals that will regain your positions.
    The best sat for all is 1west.
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    Have lost signal looks like cable has come loose, also the system was set up in 1.2 not usals, will have to get ladder out to check cable, have had system working ok till down loaded channel list did not understand it would change system to usal and delete all positions. will check cable and then move dish through arc to save sat positions again.
    Sh*t Happens
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    if your pole is straight all the way around its easier using usals than it is diseqc1.2........but if you decide to try usals you'll need to find out your long/lat seetings by imputting your postcode in Worldwide map search, route finder and travel directions - powered by Multimap
    PS3= krazylegz120282
    please read the rules >>>>http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    if you're new to forums and want to make your first post please read here>>>>http://www.digital-kaos.co.uk/forums...ul-tips-30279/
    if you like what people say please use the reputation or thanks button, dont just make a post to say thanks
    Oct 2008
    Pole is straight been checked and rechecked, have reset all sats working fine now , Have down loaded latest patch, need more info on what to do next to increase enjoyment , best sat for films and sport, do i need to buy a cam etc, its a Technomate 6800 hd , also what settings do i need to get ITV HD as it does not appear in any my channel lists, how do i get discovery HD or do I need to by a cam etc.
    Aug 2008
    var/tuxbox/plugins
    for disc. HD you will need a cam[diablo best].
    you will gat a lot of enjoyment with a diablo 2.3
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
