Results 1 to 14 of 14
Thread: DM 800
    DK Veteran Walkinmyshadow's Avatar
    Nov 2008
    In a very strange place!!!
    Default DM 800
    Alright guys, You gotta help me out here please, i have a dreambox 800 and i think im a little over my head, had a good look around the forum as suggested by the boss and managed to flash gemini2-350 to the box, i also managed to open up flashfxp and drop in the keys and scee from dreamboxstuff, all was well i thought, connected up my dm800 to my tv and now its just constantly trying to boot but it cant it seems...any advice would be appreciated
    Top Poster icaicm's Avatar
    May 2008
    In Here
    seems like a bad flash. reflash it and see.
    Jun 2008
    they do take a long time to boot leave it alone for 20mins
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    moved to correct secion m8
    PS3= krazylegz120282
    please read the rules >>>>http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    if you're new to forums and want to make your first post please read here>>>>http://www.digital-kaos.co.uk/forums...ul-tips-30279/
    if you like what people say please use the reputation or thanks button, dont just make a post to say thanks
    Nov 2008
    Ok flashed it again and now it wont reboot by remote or manually) is it safe to just unplug it??... thanks for the help guys
    V.I.P. Member thered's Avatar
    Aug 2008
    yeh id turn it off leave it 30 seconds and turn it on
    Nov 2008
    nice one... that worked.. cheers, now if someone can explain to me (in layman's terms) how to install evocamd i'll be grateful
    Moderator
    krazylegz's Avatar
    Mar 2008
    if you have a router connect it to dreambox using rj45 and you should be able to download it from the gemini addon server.....not sure which button as i dont like gemini but will be one of the colours probs blue
    Aug 2008
    just to confirm krazylegz is right blue button/addons/geminiserver/cams
    or if you are not networked you can manually install
    ftp to temp then bluebutton/addons/manual install cam will be installed this will work for gemini
    http://rapidshare.com/files/15956403..._071231.tar.gz
    keep it in its form do not unzip just put in temp the box will unzip it for you
    Nov 2008
    Thanks for the help guys, but im back to scratch, box is not booting again, maybe it's gemini?? what about enigma2 jade? anyone got an opinion on that?
    V.I.P. Member 2tone's Avatar
    Jun 2008
    if i was you i would reflash the factory firmware on to it then boot it up and see how it go's you can get this on dreams site it will also be the up to date one with all new drivers see how it runs if all ok then flash with gemini
    Nov 2008
    Cheers 2tone will try that.. a complete novice at this.... but im learning..fast, looks like i cud be around for awhile
  13. #13
    Nov 2008
    Can you suggest good settings for DM800?
  14. #14
    Jun 2008
    Quote Originally Posted by worth2 View Post
    what settings
