Hello.
I noticed the magic patch dated 15/07 says fixed digi tv au.
so when I load the new soft cam, do I need au on or off????
Sorry am thick but appreciate your advice.
Hello.
menu>options>set the digi-tv A/U to on
and if your useing the latest patch from
15/7/09 the patch will auto update the keys for you
you dont need to load the softcam unless you dont want to
wait a few mins for the key to update. it wont give any probs if you load the softcam
Please Read Carefully!
Thanks for the prompt reply Benny, as always great help.
So do I understand right, once I load the new patch (which I did last night), I wont have to load softcams again?????
Would I then have to load the next patch? what I'm trying to ask is would Digitv be open for a good while???
thats correct mate the latest patch was to fix the digi-tv A/U thats why you need the A/U turned on in the menu options and when there's a key change you just leave it set on a digi-tv chn and the patch will update the key for you. as for how long it will keep updating that depends on the provider, if they make a major change that could knock the patch A/U out and stop it updating, then you need to load the softcam again,there wont be anouther patch untill some thing needs a fix
or there is something new that the patch can open.
Cheers Benny.
The keys change that often thses days you loose track where your up to.
I have a TM3200
So it doesn't have the AU facility option is that correct
I have noticed a couple of time when I go to enter Keys before I can enter it updates.
So as its patched do I just wait for 1W to update itself each time?
am not too up on these things, but have not seen a patch for 3200 with AU fixed.
Someone will be along in a minute with more knowledge than me.
there isnt a working au patch for the 3200 m8
either enter keys via remote or load latest softcam
PS3= krazylegz120282
Strange
Last night I switched to Digi to enter the keys got called away and when I came back Digi was clear again
Second time this has happened
Thats why I thought it was AU
Either that or I had been at the Gin again
Colin
Au is working on 3000init? Im sure of it!
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 Motor
Is there a DighTV AU for the TM6800 yet
No but i can tell you that it will be here soon!
___________________
TM500
DM500s
the tm 6000 hd boxes have always been the last in line for patches
it's the same for the clarke-tech 5000hd thats the same spec as the tm 6900
i often wonder if it's more difficult to make patches for the hd models
but it's not much trouble to load a softcam
is there a working patch for au digi 1w for the tm5400ci+usb
ive tried 260509 but get memory error
thanx![]()
I have the tm5400 and patch working - no problems.
Tom
