Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 140
  1. #121
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by zorans View Post
    need immo off with u1600 off.
    Thanks in advance.
    press buttons if all is ok
    https://mega.nz/#!ErJ32IyL
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  2. The Following User Says Thank You to kiszka For This Useful Post:
    zorans (15th January, 2020)
  3. #122
    Mar 2010
    Default Fiat dukato 2.8 edc15c7 immo off 0281010486
    Also need immo off for test second ecu
  4. #123
    kiszka's Avatar
    Aug 2009
    https://mega.nz/#!tzQVFCAJ
    Reality of life :
    3:Everyone lies
  5. The Following User Says Thank You to kiszka For This Useful Post:
  6. #124
    Oct 2016
    hello there i have fiat ducato 2.8 jtd 2001 with bosch 0281 010 454. i want to swap used ecu i want to turn immo off i think i must right? and if im right where is immo stored in eeprom or flash ? what i need to read? any help please
  7. #125
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by Davor12 View Post
    here your answer............:
    https://www.digital-kaos.co.uk/forum...10454-immo-off
    need help
    now my goal is to buy xp-005
    who will help?
  8. #126
    Jul 2010
    hello DK friends
    can someone help with immo off for Ducato 2.8 . 0 281 010 486 . 29F400TC flash file attached .
    thank you my friends
    please add rep & thanks if my post was helpful
  9. #127
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by sparkle View Post
    hello DK friends
    here.......................
    need help
    who will help?
  10. The Following User Says Thank You to rafal For This Useful Post:
    sparkle (19th March, 2020)
  11. #128
    Jul 2010
    thank you RAFAL .
    do I need to disconnect immo box ?
  12. #129
    rafal's Avatar
    Jul 2010
    UK - PL
    yes...................
    need help
    who will help?
  13. The Following User Says Thank You to rafal For This Useful Post:
    sparkle (20th March, 2020)
  14. #130
    Bllinda's Avatar
    May 2010
    Baltic
    Disconnected .... ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  15. The Following User Says Thank You to Bllinda For This Useful Post:
  16. #131
    Aug 2016
    in the zone
    hello guys. i have a project boxer with ecu 0 281 010 931 non start. i tried immo off file (flash 29f) from a good member and van start no problem. i use same file on a spare ecu and van starts no problem. i remove ecu for safe keeping and come back 4 weeks later and plug ecu and van dont start. Original ecu fuel pump primes and van dont start. Spare ecu fuel pump do not prime and van dont start. both ecu i wrote immo off file in flash and both worked and now 4 weeks later van dont start. immo box disconnected. the strange thing is that both ecu give different fault (one ecu fuel pump prime and spare ecu fuel pump dont prime). Both ecu same part numbers.
    Can eeprom cause this problem. I never touched eeprom 5p
  17. #132
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    no, its not eeprom issue, you can make eeprom virgin only if MIL is on after start, or start and rev. The problem is in the VAN, not ECU, check fuel pump in tank
  18. The Following User Says Thank You to Shmortz For This Useful Post:
    sagie1zn (13th April, 2020)
  19. #133
    Aug 2018
    East Pole
    Quote Originally Posted by Shmortz View Post
    I can confirm that. Found brocken wires to two of these fp connectors. Also, you can try powering the fp with wires from battery and see if it works.
  20. The Following User Says Thank You to volorucinski For This Useful Post:
  21. #134
    Aug 2016
    in the zone
    thanks for response guys, fuel pump is good, i used 12v probe to test. what make me suspect ecu file fault is that 2 ecu, same part number, from same type boxer, write same immo off file BUT one ecu make fuel pump prime with ignition on and other ecu no fuel pump prime with with ignition on. Both worked 4 weeks prior. i understand that it could be fault in van like maybe diesel or injector or wiring but like i say both ecu start the van and then 4 weeks later both ecu give different fault and both non start
  22. #135
    May 2010
    Croatia
    Hello
    Need to remove U1600 from Fiat Ducato 2.8,ecu is 0 281 010 931,anyone can do it?
    Thank you ...
    Regards
