Page 140 of 141 FirstFirst ... 4090130135136137138139140141 LastLast
Results 2,086 to 2,100 of 2105
  1. #2086
    Feb 2024
    Quote Originally Posted by newone View Post
    08782................
    I thank you very much, I am saved since my original key, the only one was failing already a lot
  2. #2087
    Apr 2022
    Germany
    Quote Originally Posted by ferrevsei View Post
    In other topic I gave you the PIN + CS an some other information...
    Porsche Cayenne 955 key prog question - Page 2 (digital-kaos.co.uk)
  3. #2088
    Jun 2016
    South Africa
    hi need pin from REC OR UEC modules for opel zafira b
  4. #2089
    rob h's Avatar
    May 2011
    7204 is your pin
  5. #2090
    Mar 2018
    Estonia
    Mazda 323F, need pin code, Denso ecu 93c56.
  6. #2091
    newone's Avatar
    Oct 2016
    Quote Originally Posted by Rando View Post
    88983812..........
  7. The Following User Says Thank You to newone For This Useful Post:
    Rando (26th February, 2024)
  8. #2092
    Mar 2011
    Hello I need pin from Body Grande Punto inside is memory 93C86
    I tested two pin 43842 and 54238 - not work
    Please calculate good PIN
    Thank You
  9. #2093
    rafal's Avatar
    Jul 2010
    UK - PL
    54238 is correct.................................
    need help
    now my goal is to buy xp-005
    who will help?
  10. #2094
    Mar 2011
    Not work this pin :-(
  11. #2095
    Zapp's Avatar
    Sep 2010
    Liverpool
    Default citroen c3 Valeo bsi
    Hi Guys I need from Valeo 24C128 BSi Citroen C3
    Big THANKS in advance
  12. #2096
    Bllinda's Avatar
    May 2010
    Baltic
    Try .... 76xd or reverse
    Quote Originally Posted by Zapp View Post
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  13. The Following User Says Thank You to Bllinda For This Useful Post:
    Zapp (25th April, 2024)
  14. #2097
    Zapp's Avatar
    Sep 2010
    Liverpool
    Cheers Buddy
    Can confirm... 76XD
  15. #2098
    Apr 2024
    Hello everyone. I have a problem with Renault Laguna 3 2009, a problem that I caused myself. however, when changing the bulbs on the front lights, the lights did not turn on while driving, and I bought renolink diagnostics and looking on the Internet I wanted to enable the turning lights and turn off the Scandinavian mode, but somehow not knowing what I was doing, I reset the instrument cluster and the error prog appeared. then after all that, I downloaded the PTB flash from the instrument cluster in the area and I'm going to load it again, but it gets to a certain moment of loading and throws an error, so now I don't have an instrument cluster, the third thing I did was because I didn't know what to fix again, I made immo uch clear and now I can't turn on the car cards, i.e. I don't have the keys anymore and I don't have a pin or anything, can anyone help me because I'm a fool? thank you
  16. #2099
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by Dejan0207 View Post
    perfect job........................... ohh no
    it is like people play with tools w/o knowledge bravo
    what you expect now by net now?
    bring car to someone who will know what to do
    need help
    who will help?
  17. #2100
    Apr 2024
    I don't expect anything, I'm just writing if anyone has a dump file, at least for the instrument cluster
    wherever I've asked someone from an electrician where I live, no one can solve my problem, so I would like to ask nicely, not so grumpily, if someone knows someone or can help?
