Results 1 to 15 of 31
Hybrid View
    Nov 2010
    Default volvo S60 2001 key programming
    HI
    My costumer lost the key ,and i make a new one ,its id crypto 48, anybody knows if is a precoding transponder or a normal one like vag ?anybody have a solution for programming the key in that car ,thank you in advance
    keygargoil's Avatar
    dealer only
    Bllinda's Avatar
    Baltic
    Question vol.vo'02 s.60
    Or so and nobody scanning the MCU, the mask? There is no access without dealer help?
    today
    A topic that interests me
    malczykos's Avatar
    POLAND
    Immo is in CEM. Memory flasch TB28F400.
    You can make transponder by using proper programmer like TmPro2, Advanced Code....
    DK Veteran gtmech's Avatar
    Hell
    Quote Originally Posted by keygargoil View Post
    dealer only
    thats not true mate, i have done keys for these before, locate flash in CEM Module and program ID48 with TMPro2, job done
    Bllinda's Avatar
    Baltic
    Question * S60
    I found only the EEPROM _c86 remember reading it. Can I help mask the wheels i C86 damp?
    today
  7. The Following User Says Thank You to Bllinda For This Useful Post:
    Neo1409 (6th June, 2014)
    Hell
    Quote Originally Posted by Bllinda View Post
    are you saying there is no flash in that CEM mate? All you can find is 93c86 ?
    Bllinda's Avatar
    Baltic
    Question
    Flash can be between the plates? I found only _c86.
    today
  10. #9
    pawliukazz's Avatar
    Jupiter
    km in dump: 81567 km
    2 keys programmed:
    CD 4F 89 EE
    CD 93 C5 4B
    Crypto keys:
    89 E7 B0 E9 51 E2 42 XX XX XX XX XX
    synchro with ecu:
    XX XX XX XX 05 46 93 94 56
  11. #10
    Quote Originally Posted by pawliukazz View Post
    2 keys programmed:
    CD 4F 89 EE
    CD 93 C5 4B
    Crypto keys:
    89 E7 B0 E9 51 E2 42 38 4B 2A 6B 6F
    synchro with ecu:
    39 64 50 72 05 46 93 94 56
    Can you decrypt all data? What you use to decrypt?
  12. #11
    Member VolvoGeely's Avatar
    Apr 2011
    Well Key is programmed in two places on a P1 platform. CEM & ECM ..
    Good luck opening up sealed Controllers , that a key , five min's on a Vida Cart ,+ Key software , It's done ..Collect $$ ,,
    NEXT !!
    Plus If a Controller (CEM,ECU,UEM,REM ) needs replacing , The Pie server can do a reload and the KEYS still work.
    VG
    DON'T Pm Me from Nigeria and ask If i will do a remote linking!!!!
    But I will get a wire transfer ? Yes ??
  13. #12
    Bllinda's Avatar
    Baltic
    I didn't look for a programmer to read it.
    today
  14. #13
    With a j2534 buy a new flash and it allows a new key in. Do not use cracked vida why you are on the web page use a different pc. I knew someone who did that?&*$^&*$&*&
    Life is like a box of programmers you never know which one youll need.
  15. #14
    Jan 2011
    Romania
    In P2 platform Volvo`s from 99 to 2004 the key information is in the flash inside the CEM, after 2005 the key information is in the eeprom .
  16. #15
    soxten's Avatar
    Mar 2013
    He use Codecard program to see this.
    Pawliukazz is great at this type of cem!
