Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Nov 2010
    Default volvo S60 2001 key programming
    HI
    My costumer lost the key ,and i make a new one ,its id crypto 48, anybody knows if is a precoding transponder or a normal one like vag ?anybody have a solution for programming the key in that car ,thank you in advance
    keygargoil's Avatar
    May 2010
    dealer only
    Bllinda's Avatar
    May 2010
    Baltic
    Question vol.vo'02 s.60
    Or so and nobody scanning the MCU, the mask? There is no access without dealer help?
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
    malczykos's Avatar
    Mar 2010
    POLAND
    Immo is in CEM. Memory flasch TB28F400.
    You can make transponder by using proper programmer like TmPro2, Advanced Code....
    DK Veteran gtmech's Avatar
    Jul 2010
    Hell
    Quote Originally Posted by keygargoil View Post
    dealer only
    thats not true mate, i have done keys for these before, locate flash in CEM Module and program ID48 with TMPro2, job done
    Bllinda's Avatar
    May 2010
    Baltic
    Question * S60
    I found only the EEPROM _c86 remember reading it. Can I help mask the wheels i C86 damp?
    today
  7. The Following User Says Thank You to Bllinda For This Useful Post:
    Neo1409 (6th June, 2014)
  8. #7
    Jul 2010
    Hell
    Quote Originally Posted by Bllinda View Post
    are you saying there is no flash in that CEM mate? All you can find is 93c86 ?
  9. #8
    Bllinda's Avatar
    May 2010
    Baltic
    Question
    Flash can be between the plates? I found only _c86.
    today
  10. #9
    Jul 2010
    Hell
    Plates? Just take off the square metal panel and flash is in there
  11. #10
    Bllinda's Avatar
    May 2010
    Baltic
    Question *.s60
    Quote Originally Posted by gtmech View Post
    I'm sorry, mislead you all. Vol.vo '05. S60 car produced in 2005
    today
  12. #11
    DK Veteran dontzapit's Avatar
    Feb 2012
    Iceland
    dealer only unfortunately if its 2005
  13. #12
    Bllinda's Avatar
    May 2010
    Baltic
    Question
    Quote Originally Posted by dontzapit View Post
    Can someone explain the reason should go to dealers?
    What is impossible to do?
    today
  14. #13
    Jun 2010
    First reason, can you read/write microcontroller renesans M32C?
  15. #14
    Feb 2012
    Iceland
    Quote Originally Posted by adam12112 View Post
    and second reason, how are you going to program remote without dealer approved subscription for Vida?
  16. #15
    Bllinda's Avatar
    May 2010
    Baltic
    Question #.s60
    Read and write with no mess Renesans M32C, I found online.
    The question of whether reading M32C controller will have the opportunity to read the EEPROM C86 outer diameters?
    Will it be necessary to sync the device with Vida When you save me another key?
    today
