Page 89 of 94 FirstFirst ... 39798485868788899091929394 LastLast
Results 1,321 to 1,335 of 1400
  1. #1321
    electronistul21's Avatar
    Nov 2011
    galati,romania
    need buy trucks kit adapter.in this kit you have and adpter for trailler
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  2. #1322
    Aug 2012
    SWEDEN STOCKHOLM
    Quote Originally Posted by fifas2010 View Post
    Autocom Cars CDP PRO 2.10.3 MultiLanguage | 2.3 Gb
    Name: Autocom Cars CDP Pro
    Version: 2.10.3
    Autocom Cars CDP PRO 2.10.3 MultiLanguage (link?s)
    pass in PM ):
    thanks to share pass pm pls.
  3. #1323
    east dublin ga.
    thanks you
  4. #1324
    pass pls!!!!
  5. #1325
    Apr 2017
    hy!
    i dont think to open another topic to my problem.
    i have a band new, but clone autocom cdp+ with data logger.
    1) installed delphi/autocom sw
    2) installed device driver
    2) win 8.1 pro see the device and com port
    problem:
    delph/autocom see the device, but cant test.
    maybe just my fault, but i cant go forward this point...please help me anyone!!!!!!
  6. #1326
    Apr 2017
    Version: 2.10.3
    pass in PM ):
    Hello, would you be so kind to give me the password of the zipped file?
    Thank you.
  7. #1327
    Oct 2016
    I have Autocom with 2.14.3 software
    I tried to connect to a 2008 Volvo xc60 with d544t6 engine. It does not response to engine connection but all the other like ABS, Immo etc. works.
    Any idea?
    UNI
  8. #1328
    gracias por compartir.
  9. #1329
    Jul 2013
    yorkshire
    Hi guys, i have 2 lap tops with 2012 on first and 2015 on second. Today diagnose a grand vitara 2.0 hdi. Air con fault! 2015 had little info, but 2012 had lots and i found fault. But when i switch from one to other, i have to update hardware and test. Is this nornal?
  10. #1330
    tek2dk's Avatar
    Oct 2012
    under the sea
    Yes, it's normaly !
  11. The Following User Says Thank You to tek2dk For This Useful Post:
    autoden (16th November, 2017)
  12. #1331
    Jul 2014
    Romania
    USB Device Not Recognized ...
    After some USB problem and repair I can`t use the autocom becouse I have USB Device Not Recognized an I don`t have idea what is it but the mark driver is USB driver ...
    Thank you
  13. #1332
    Dec 2014
    PL
    Quote Originally Posted by autoden View Post
    Hi. To avoid every update in 2013.1, 2014.2, 2014.3, I have pasted the firmware (1423) from WOW Wurth 5.00.8.2 to everyone. Now my scanner works with 2013.1, 2014.2, 2014.3 and WoW Wurth. Delphi 2015.1 has a bit more new cars from 2015 but there is no description of errors. In my opinion, it's better to use 2014.2 or 2014.3 than 2015.1.
  14. The Following User Says Thank You to Mario6 For This Useful Post:
    Col19 (31st October, 2019)
  15. #1333
    Dec 2014
    PL
    Quote Originally Posted by bebyutza View Post
    Thank you
    Hi.
    Check the controller device manager 1) VCI (Diagnostic unit) and 2) Port (Com Lpt.) Try to reinstall both drivers. Check also in: details, device ID -VID and PID.
    I have: FTDIBUS / COMPORT & VID-0403 & PID-D6DA. You can also check if MPROG 3.0 detects the interface. If the PID is for example 0000, the program will not detect VCI.
    If it does not help, translate and read. Maybe you can find a solution to the problem.
    http://autocom.ucoz.com/write.html
    http://obd2-diag.blogspot.com/2016/0...141-20133.html
  16. #1334
    Nov 2015
    Please can you send me the password?
  17. #1335
    Feb 2018
    I have posted my problem on a new thread before reading this. It's here.
    Could someone help me on my issue? My board is working but it doesn't connect with the ABS. Do I need to modify anything on the PCB?
