Results 1 to 15 of 20
    Bllinda's Avatar
    Baltic
    Default Crash Sensor Side, driver side (G179)
    I need your help. I can't adapt an used G179 for this car: Vw'01 Golf IV 1.4 16v MPI.
    Maybe someone has the photo of the disassembled G179?
    Address 15:
    Part No: 6Q0 909 605 A
    Component: AIRBAG VW5 01 0004
    Coding: 12358
    Shop #: WSC 01317
    Faults Found
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    37-00 - Faulty
    01221 - Crash Sensor Side Airbag: Driver Side (G179)
    62-00 - No or Incorrect Adjustment
    today
    A topic that interests me
    Bllinda's Avatar
    Baltic
    Default Crash Sensor Side G179
    Does anyone know why can't I change this sensor from other car, which didn't have a crash?
    today
    mcm44's Avatar
    If crash sensor number is 6Q0 909 606, then you need to match crash sensor ID, not only the part number...
    Bllinda's Avatar
    Baltic
    And then be able to adapt?
    today
    afonso rico's Avatar
    guimarães
    hello
    this ecu is compatible with the elements of the car?
    this ecu is the same car? or has been repaired
    Bllinda's Avatar
    Baltic
    I changed the G179 and the sensor can not adapt to the ECU.
    ECU is an accident has been deleted.
    today
    You have to connect correct sensor part#. No adaptation is required.
    Bllinda's Avatar
    Baltic
    Will be the same as the num * 20000483 * 02310D0FGTHA: will be okay
    today
    mcm44's Avatar
    Quote Originally Posted by mcm44 View Post
    Did you saw my previous post? Did you know what crash sensor ID is?
    Bllinda's Avatar
    Baltic
    I didn't understand the question, or don't know where to find the ID. There's a picture i uploaded, isn't that the ID you asked for?
    today
    mcm44's Avatar
    This should clear the case...
    netherlands
    where did you get this nice info from?
  13. #13
    mcm44's Avatar
    Ross-Tech.com
  14. #14
    Bllinda's Avatar
    Baltic
    Quote Originally Posted by Bllinda View Post
    Address 15:
    Control Module Part Number: 6Q0 909 605 A
    Component and/or Version: 0F AIRBAG VW5 01 0004
    Software Coding: 12358
    Work Shop Code: WSC 01317
    Faults Found:
    37-00 - Faulty
    This encoding should be:
    Coding: 12338 - Configuration is: 4 airbag, 2 seat betls, 2 side-crash sensors.
    And I did not find 12358 and also haven't found the difference between them.
    today
  15. #15
    mcm44's Avatar
    Address 15:
    Faults Found:
    37-00 - Faulty
    I think coding is ok in your case.
    I marked in red, what is your problem. Crash sensor driver side have to be replaced, because DTC 1221 is described "Faulty".
    If you install incorrect crash sensor (ID other than 01) you will get DTC 1221 with description "No or Incorrect basic settings / adaptation".
