Results 1 to 11 of 11
    Top Poster + iphonic's Avatar
    Default Priiloader on 4.3E
    I have installed the hbc and then i installed the WAD files and then i go to install the priiloader program but when i try to the screen just goes black and blank and i have to turn my wii off from the wii to resart it back up again does any one know how i can safely install the priiloader?
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well it depends on which system version your using. Post a sysCheck as instructed in that link so we know which wads you've installed.
    You will probably need IOS36 and IOS58 installing. If you're going to use USB Loaders then you may as well install Full Cios wad pack afterwards which has d2x v8.0 inside.
    Keith
    2010 Golf GTD (170)
    Quote Originally Posted by Keithuk View Post
    Priiloader installed after a few trial and errors, probably somthing i was doing wrong. Whats the best stable program to use for loading games through a usb? I have usb loader installed already but have not got roud to using it yet is it any good?
    Aug 2010
    England
    It depends where you had your PriiLoader v0.7 from and did you have hacks.ini and hacks_hash.ini on the root of the card?
    As you will read in my sig I have the 3 main USB Loaders but I only really use as its the best USB Loader GX the IOS249 version. You will need cIOS236 if you want to use USB Loaders.
    You haven't said which Wii version your using as when you install PriiLoader it says on top of the screen uses IOS58 and only 4.3's have that installed by default thats why I suggested it.
    Keith
    2010 Golf GTD (170)
    When i get home im guna take some pics and upload them on here and if you could tell me what i need and dont need would be great, im not sure what wii im using i will check
    Aug 2010
    England
    As I said post a sysCheck so we know how your system is.
    Keith
    2010 Golf GTD (170)
    Nov 2012
    Default Same problem
    Quote Originally Posted by skyla20 View Post
    I am currently having this same problem. Is there any alternative solution?
    Aug 2010
    England
    Welcome to DK.
    Quote Originally Posted by aaals View Post
    Have you done whats been suggested?
    Post a sysCheck as instructed in that link.
    Keith
    2010 Golf GTD (170)
    Jan 2013
    Thanks for the file.
    Feb 2013
    Default Thanks!
    Thanks for the help, I was looking for this wads for a while now! =)
  11. #11
    Mar 2013
    Yeah buddy
