can't get to the dish and don't know where the hell it is pointing now after all the messing about i have done. if i fit up my fortecstar unit that i know works and get that onto 28.2 then disconnect every thing it should stay in the same place then connect up the dream box and see if it works on 28.2
tonynw.
If you can move your dish with another unit then there must be a problem in your configuration of the tuner. If you like I will walk you through my setup it should be same as you have if not then problem solved but I need an hour before I can do that.
not trying to make a tit out of you mate , but you are hooking up to the "in" and not the "out" on your dm800
yeh , i agree with andy , if there is no tone aplitude section on tuner config then summit aint right .
this 2nd box tony , did you flash it with the image thats on it ?
if so i would re-download and reflash the image again mate
setup 800 to screen only and removed all the settings for motorised and just set to single lnb, then i connected my old unit and set it to 28.2 the dish has moved to 28.2 switched off the box un plugged everything so dish should stay in same position, i then connected to 800 up selected astra 28.2 went to granada n/west and nothing no signal strength and after about 20 second got a message to say tune failed that is what i have been getting all the time.
tonynw
check your connections mate , the dm800 tuner may be more sensitive than the other box you got,
also did you see the guy swap it , or is it possible he blagging you
used network today to download cats eyes on the box i took back so would think this will go on network ok
tony
sorry if i'm off topic
