Hello, I want to read my vw ecu, but in all Carprog versions Im trying, it is N/A. Is there any solution to make these functions working? Im using chinese clone. Thanks.
When Im connecting device, i got this message:
It's will work with the adaptor A1+ .
And the firmware must be FULL
mikroel (15th August, 2016)
OK
I need help
Passat B6 2007 i try to change km with carprog but all time i got message "connection error"
What is the problem??
Last year i try on similar B6 and i make change on km
What is now problem??
""Just press THANKS when you think it is useful""
OK
What adapter A1???
Can you help me
You need to check if you need power supply on carprog +12v !
Sorry for the question off topic. In order not to create a new ....
Is everything works car.prog 8.21and the9.31 off-line? Thx
A topic that interests me
I have UART1 - error during testing with A9 test adapter. Do you have any solution for this? It's original one and I have already replaced all 74HC125M.
Levanime (21st September, 2016)
