how about clone ford texas 4d to 4d is it possible?or just work on toyota 4d to 4d?
cs and need pin code, used ecu.
thank for help.
JETTA 0261S06216 MED17.5.2 T PROT.rar
What works transponder chip for ID63 4D Ford or Mazda? cheap
because I can not uncheck the lck of pg4 and record with zed bull clone of a 4d 63
when and record distanced gives me error not record me
Can somebody tell me if it will work to pre-code megane/scenic II smart card with pcf7943 if I choose Renault pcf7947 and the correct card from the Image Generator menu?
I know with AVDI you have one common function for both transponders(it doesn't matter which chip you use as long as you replaced the old one with the same kind) but I couldn't find info about EFFI and 7943.
EDIT:
According to PDFs - Tango does it the same way as AVDI - one common function for both 7943 and 7947, but has separate function if the card is for Megane or Scenic... And Effi has only one - 7947 for Megane ...so will it work?
Are you sure that avdi can precode a renault hands free card with pcf7943?
I know every decent tool can cope with the 7946/7947 but not the 7943.
ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
ninja
And whats happened to EFfi updates? Been used to them that regular but nothing for a while now
ninja
Hello, friends
How to prepare an empty PCF7946 programming to understand the Tech2? Saab 93 SS 2003.
Thanks.
Best regards.
P.S. Tmpro2_module_111_Tango
A topic that interests me
Go to Image Generator->46 Crypto->SAAB->PCF7946
done another 2007 punto today, and the remote key precoding does not work, this is the 3rd one that ive tried and the remote will not work
ninja
Phase 4 autokey (1st May, 2014), whiskeyman (1st May, 2014)
