mexanico1971 (8th October, 2016)
Hello at me it turned sew AT91SAM by using SAMBA Atmel SAM-BA In-system Programmer by USB . I used the manual for restoring JLINK V8 china clone . I am a great hurry and established at91sam256 carprog PCB jlink . after programming set in at91sam256 carprog and at me all earned. I did not have time to make detailed instructions I will try to do. to work with samba you need to install quartz 18.432 MHz
1. Stuck in the USB cord and closed the tweezers to place the first jumper 30 seconds - so that the end to clear the memory. Disconnect the cord.
2. Stuck in the USB-jumper closed the second for 30 seconds - restored loader.
mexanico1971 (8th October, 2016), obd.tech (13th April, 2013)
Confirmed! Problem with Chinese clone causes 74HC125 if the A9 test connector all results "OK", but still can not read most of EEPROM and MCU.
If you do not read 24Cxx, 93Cxx and other series EEPROM, or reads, but with bugs and verification is not good, it is necessary to replace all 74HC.
I replaced all old 74HC125 and put 74HCT125D (Philips) and the device work properly.
Problem creating level CMOS (HC series). When you put the HCT series (TTL level) communication regularly, without fail.
In some cases the problem can generate power devices with a USB port, so after replacing HCT (TTL) is very desirable to bring external power 12V CarProg.
Voltage drop that is generated on the USB cable and within the device will not be enough for TTL HC series in some cases.
HC series works in the range from 2.6 to 5.0 V - Vcc
HCT series works in the range from 4.5 to 5 V - Vcc
When you use HCT series is TTL level ports in most cases guarantees proper communication with external eeprom, mcu ....
I hope I have helped someone with this.
Cheers ..
hbfj (7th March, 2017), mexanico1971 (12th April, 2013), mohamedkey (18th August, 2013), obd.tech (13th April, 2013), Oto kilitsan (16th January, 2021), Patrone (6th March, 2017), shadab (14th November, 2016), Zmann (24th April, 2013)
this is original schematic from codecard.lt
cubica1 (15th April, 2013)
Hi all,
Make all what i say in my Post 132 and this resolve all problems!
http://www.digital-kaos.co.uk/forums...ml#post1882950
I used 74VHC125M and work 100% too
o try to erase but when i try to conect with jtag when i try to find targen say me this " unable to find target "
here are conection help me plz
Hi friend, one question about your fix solution: there are 3 yellow condensators, you suggest to change them for 22mf but they are marked as "106 C" that means 10mf, in the older version of carprog the 3 condensators are 22mf but in the newest carprog they are marked as "106 C" = 10mf.
Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
jarripote (25th December, 2013)
I use 47microfards condensator
Thanks, I replaced the 4 HC125D with 4 HCT125M, the 2 10pf condensators, the 5v regulator, the 12mhz oscillator, installed the missing condensators of 100pf, isolated the motherboard and now is working perfect, but I doesn't change the 10mf capacitors, anyway, the clone carprog is working well. Thanks for your help. BR...
Oh i don t see it OK
message deleted
need help.
I want to change serial number CAR prog.
have a new full carprog Lib file for a new serial
I make change serial into dump, and add new lib file.
Run.
select any , for example airbag.
Software says - bad CRC!!!
but idont know, how calculate crc !
How can me do it?
Tereksaz
