hello this is my pic from my vag kkl with chip ml339
plz see if is work
plz see if is work
HI,
Free version works with any simple kline interface, vagcan adaptation is needed for EZS reading only.
Is your interface recognized by my software ? maybe you haven't adapted the interface as it should be done ?
For basic operation the pic isn't used at all (bypassed).
regards ficho
proginfo (28th November, 2015)
A topic that interests me
martinracing (26th May, 2020), mexanico1971 (29th May, 2019)
A. 2,3-30;4-15
B. 3,8-31
HI,
You have to connect to diag pin, and before start reading insert a dummy key in ezs to wake up mcu's
regards ficho
antonypaul (22nd July, 2023), Artilect (3rd January, 2017), Bllinda (22nd December, 2015), gobe (28th August, 2019), Locksmith Hungary (22nd December, 2015), martinracing (26th May, 2020), mecatronicuruguay (20th May, 2017), mexanico1971 (29th May, 2019), mohamedkey (24th December, 2015)
the result is the same "error reading !!!" I've tried the xp-sp3 and win7x64.
Only I do not know good acting key.
Click lock, unlock not flashing LEDs.
Batteries are new.
Big plastic key inside 567830051(g72 2buttons) or even 6561672070(f82 3buttons)
ficho. Thank you for your patience.
Best Regards
Bllinda
Are you able to read esl only?
just connect esl to power supply and kline.
regards ficho
olegzom (13th May, 2016)
as can be read directly connect to kline.
ficho
What I could suggest to you in exchange for the full version w.E.S.L? Thx
Which to connect wesl with w210 eis as esl emulator?
It is possible with vagcom k-line adapter?
Can read w210 esl via k-line all or partial?
Thank you!
Hi FICHO!
Their software is compatible with this interface to RENEW ESL (MERCEDES W204)?
Could someone provide some software that is compatible with this electrical interface, to renew the ESL of Mercedes w204, when the ESL's DC motor has been replaced?
