    Senior Member tony2803's Avatar
    Jun 2008
    Default skybox m3 set stb memory error
    hope someone can help me please,i have a skybox m3 that is just showing a red light on front panel,have read tuts on how to recover box with upgrade tool,i have set all this up and I continuously get set stb memory error,does anyone have any idea how to get past this error message or what I may not be doing to put new firmware onto box so I can recover and use m3 box again...thanks in advance. just to add I have tried usb to serial cable and the serial cable that came with box this was connected to a null modem cable into rs232 of pc using xp pro.
    P&D's Avatar
    Hi mate i believe that the red light is a hardware failure not software
    how to flash your box Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    V.I.P. Member lagerland's Avatar
    Sep 2010
    Right ere Right now.......
    Had that on a s10 it was the power board......................
    I am not sure you realise that what you heard is not what i meant !
    Jun 2008
    Quote Originally Posted by tony2803 View Post
    after quite a few different attempts in different ways I have finally recovered this m3 from becoming a doorstop,it is now up and running,with patience cometh results...
    Nov 2013
    how did u fix it then
    Yea how did you fix it pal?
