Page 1 of 41 12345611 ... LastLast
Results 1 to 15 of 601
    Administrator
    Devilfish's Avatar
    Feb 2008
    Default ### Digital Kaos v1 Dreambox Image for DM500 C/S/T ###
    Well it's been a long time coming but it's eventually here - Digital Kaos v1 image for all versions of DM500, cable satellite and terrestrial.
    Please read this post in full before asking any questions. All questions with answers in this post will be referred here.
    A few details about the image!
    Yellow - Kaos Panel (Extra settings, Manager suite, User features)
    Blue - Plugins (preloaded with a few)
    Red - EPG (double press to bring up a few options including EPG Search)
    Green - SubServices for satellite viewing, i.e. Premiere Sport Portal. Also if you hold it down for more than 3 secs it shows the DVR controls for recording.
    Info - Infobar popup as usual but hold down for more than 3 secs to bring up the EMU Manager, kind of a hidden menu.
    Kaos Panel
    Kaos Extra Settings
    --Loads of extra settings in here, have a look and have a play
    --Enable picons (/var/etc/picon)(attached) These are icons that show the channel logo, takes up room in /var so it's disabled by default, can also be downloaded from the addons menu.
    Manager Suite
    --Addons Manager - Download plugins, emu, configs, etc
    --Slot Manager - For smarcards (sat)
    --Infobar adjust - Adjust the position on the infobar on your screen
    --Backup Manager - Backup your settings, plugins, skins, config, services, bouquets, etc. File will be generated in /tmp called backup.tar.gz.
    --EPG Manager - Not used on the DM500.
    --Audio Language Manager - Set priority languages for satellite users.
    --Var Move Manager - Move /var to the /hdd, or /usb devices, not used on the DM500.
    Addon Manager
    --Install Local Addon - copy file to /tmp and install using this option
    --Server: DK Addons - Internet addons available to download
    --Uninstall Addons - Uninstall any addons you have installed
    User Features
    --Flash Image - Copy img file to /tmp and rename to backup.img
    --ServicesBackup - Creates a services.tar.gz file in /tmp with all services and bouquets
    --ServicesRestore - Restores services.tar.gz if placed in /tmp
    --ReloadChannels - Reloads channels if services or bouquets have been manually altered
    --BackupImage - Creates a backup.img file in /tmp - this is a complete backup
    --PanicButton - Removes emu, keys, roms, services, bouquets, etc...everything to make it a FTA image. A factory reset or reflash is required if you select this option
    Included Plugins
    DreamNetCast Internet Radio - Listen to internet radio if your dreambox is connected to the internet. Add stations in the /var/etc/stations.xml file.
    RSS NewsReader - Read RSS feeds on your dreambox. Including the Digital Kaos forums. Edit the /var/tuxbox/config/rss/feeds.xml file with your own feeds, although some have been added for you.
    Tuxbox Commander - For editing the filesystem on your dreambox.
    Teletext - Available via the 'TEXT' button on remote or via the blue button menu.
    Internet Image Updates
    All future image releases will be available to update over the internet.
    Menu > Setup > Expert Setup > Software Update > Internet Update
    If you are currently using a DW image and you want to copy your services and bouquets to this image, do the following...
    Using remote, Blue > User Features > ServicesBackup
    FTP to your dreambox and navigate to /tmp.
    Copy the services.tar.gz file to your PC.
    Flash the new DK v1 image.
    Copy the services.tar.gx file from your PC to your dreambox.
    Using remote, Yellow > User Features > ServicesRestore
    Exit out all menus, hold 'INFO' to bring up the EMU manager and press OK to start
    DO NOT COPY YOUR WHOLE /var/tuxbox/config/enigma FOLDER TO THIS IMAGE!!!! IT WILL NOT WORK!!!!
    No Keys or Roms
    This image is supplied without any keys or roms. It is a FTA image only!
    But I did find that someone has uploaded these files which appear to work fine with this and any other image.
    db_magic_files.rar
    Copy contents of Keys folder to /var/keys
    Copy contents of Scce folder to /var/scce
    Go to Sky Sports 1
    Hold INFO for more than 3 secs to bring up EMU manager, press OK.
    Wait.......
    Screenshots
    http://www.digital-kaos.co.uk/images/dk_info.png
    http://www.digital-kaos.co.uk/images/dk_panel.png
    http://www.digital-kaos.co.uk/images/dk_emu.png
    http://www.digital-kaos.co.uk/images/dk_addon.png
    http://www.digital-kaos.co.uk/images/dk_infobar.png
    Thank You
    Special thank you to all members of the Merlin Project Team, Nemesis Team and CLi Team. Also thanks to all beta testers, your input is very much appreciated.
    Digital Kaos - Downloads - Digital Kaos v1 Image for DM500 (cable and sat)
    Updated v1.1 Image here
    Fully information regarding picons can be found here...thanks Jasmeet_87
    Njoy!
    -Devilfish
  2. The Following 5 Users Say Thank You to Devilfish For This Useful Post:
    as1969 (6th August, 2024), catalinosonesti (3rd December, 2019), efrenl (28th March, 2018), wacky (6th August, 2014)
  3. #2
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    great work devilfish .. top image .. as always lads can we have some feed back on wot u lot think aswell ..
    the PanicButton is a great idea aswell glen - Removes emu, keys, roms, services, bouquets, etc...everything to make it a FTA image. A factory reset or reflash is required if you select this option , that will cheese cable of if they knock the door
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    nice one glen m8.
    can confirm this is a nice image and runs well on satellite
    PS3= krazylegz120282
  5. The Following User Says Thank You to krazylegz For This Useful Post:
  6. #4
    Apr 2008
    Default re:
    Just installed this onto my dreambox and it seems to freeze get confused very easily, in the last hour it has frozen about 5 times whilst I have been playing around with it, may just be my box though. Keep up the great work guys. Will leave it on and give it a descent run !!!!
  7. The Following User Says Thank You to scottish-lawd For This Useful Post:
  8. #5
    Mar 2008
    birmingham
    lv been testing this and few others and its been fine wot cam u using
    and how did u get the image with 4 posts?
  9. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  10. #6
    Dreambox Guru osborne82's Avatar
    Mar 2008
    any dreambox development forum
    glad u finaly got it out glen top work bud
    cheers
    osborne82
  11. The Following User Says Thank You to osborne82 For This Useful Post:
  12. #7
    Mar 2008
    birmingham
    Quote Originally Posted by osborne82 View Post
    cheers
    osborne82
    hows it compare to your dw2.1 image m8 ..... dont answer that .. only kicking ...
    image fight
  13. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  14. #8
    DK Veteran Saltire's Avatar
    Apr 2008
    Scotland
    Cool
    thanks for the new image, BUT, , can we please have a version that we can flash using dreamup and also includes the latest autoupdating rom fix's and so on.
    thanks.
  15. The Following User Says Thank You to Saltire For This Useful Post:
  16. #9
    Mar 2008
    birmingham
    Quote Originally Posted by Thomson View Post
    thanks.
    cant u use ftp m8 ? save your files in keys and then put back on ?
  17. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  18. #10
    Member dedge_10's Avatar
    May 2008
    NOTTS
    Does this version support whats on now and next
  19. The Following User Says Thank You to dedge_10 For This Useful Post:
  20. #11
    Apr 2008
    Scotland
    Cool
    Quote Originally Posted by smirnoff_rules View Post
    simple answer mate "no", ive never been able to and i dont even want to try again as its always been a headache for me.
  21. The Following User Says Thank You to Saltire For This Useful Post:
  22. #12
    Top Poster icaicm's Avatar
    May 2008
    In Here
    good work guys keep it up. looking forward to trying it out.
  23. The Following User Says Thank You to icaicm For This Useful Post:
  24. #13
    thommo
    Guest
    its a beut, ive been using it in beta stage for a while now and i cant complain one bit,
    and now its finally out for the masses, you may say im biased but im not this kick's ass of any other img ive used to date...yeah yeah i hear you say bs mr dk mod....but no seriously id have said the same thing had i not even been a member here.
  25. #14
    Junior Member Jonny_doe's Avatar
    May 2008
    South West U.K.
    Nice one guys , many thanks for this , i'll try this out tomorrow , (kids watching tv at the moment )
  26. #15
    Senior Member mark015's Avatar
    Apr 2008
    guys ive now got flashxp working first time its happened wow,anyways i want to put the new image on kaos one,i dont want to lose any roms and channels listing ive already got on the old dodgy image so wats the easiest way to transfer the new kaos image to replace the dw2 image. without losing any of the important info cheers .
