now stuck on standbye
How do you know the cap is fine, as it doesnt need to show visual signs of failure. An ESR meter would give you a definitive reading ahead of a multimeter.
Also a cap contains a charge even when box is unplugged, so take care when inspecting it. Try reverting back to the previous firmware you had on it first.
ty but box was 100% working till i flashed it with wrong firmware i think which put it in standbye mode but all firmware for red and blue old and new comes up with not fit for reviever
Can you post which previous firmware version you had on it please.
i start the download to box and then put power lead in
ufl max red 10 04 08
Have you tried the flash without unplugging the box or have you tried it by pressing the micro reset button on the main board while flashing?
It sounds like a clone box flashed with genuine firmware, however the box would show no sign of life so this is not the case.
sorry about this pal ty again for your help,the box acourding to the guide checks out as an original red max i even took cover off and checked it against the original picture,ok every time i have tried to flash the box with an ufl firmware it comes up with not fit message.i loaded a dnupman file it loaded ok but put box in standbye,can start the ufl firmware download then put power chord in and it comes up with the not fit message hope this helps u understand sorry if i am confusing,before the flashing i went into system information and it had the old firmware dated 10 04
I got that thanks for putting it all togetherHave you tried the reset switch?
Failing that the bootloader may be corrupt and can be fixed with a Jtag. I would try the reset switch first.
is it just a case of powering up the box and pressing the reset micro button on the board??is that how u do it??
1 - Start flash update.
2 - Press reset button inside the eurovox.
3 - Apply power while button is pressed.
4 - Release button and the firmware update should start.
hello my eurovox red box has been updating for ages now, does it need new firmware again? if so where can i get it from??
have a look here m8 ---> http://www.digital-kaos.co.uk/forums...firmware-9787/
