Results 1 to 5 of 5
Thread: Sky box F5s
    Nov 2008
    middlesbrough
    Default Sky box F5s
    Hi I'm a newbie just got the F5s box put upgrade on box and it keeps rebooting, any ideas on how i can stop it rebooting so that i can get into the menu.
    thanks mark
    Apr 2011
    Sorry I cant help you but im curious does a F5s have a USB socket at front or only at the back of the box?
    P&D's Avatar
    Quote Originally Posted by twinnie2 View Post
    thanks mark
    Remove the sat cable see if it stops re-booting if it still does
    Sounds like you have loaded the wrong firmware....did you make a backup of the box before messing with it ???
    you now need this link..Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    Can i ask why your messing with the firmware ???? if the box was working which i guess it was if new....why you messing with it ??
    and now you have to learn a new trick to fix it....
    Nov 2008
    middlesbrough
    Quote Originally Posted by amjadhussain View Post
    No the USB port is at the back.
  5. The Following User Says Thank You to twinnie2 For This Useful Post:
    amjadhussain (5th February, 2014)
    Nov 2008
    middlesbrough
    Sent the box to be checked found out its a Clone, getting returned to the EBay seller.
