smokinjoe (28th August, 2022)
A topic that interests me
Solved !!!
Hello everyone, can anyone help with virgin edc16c36 Opel Movano. There is an eeprom stock and an eeprom donor. There is a programming error hanging in the stock eeprom p062F, there is no engine start. I really need your help.
Try this fiel.
NoLegal (14th October, 2022)
if you still need it, it's supposed to work fine
https://mega.nz/file/Bj4T0Bgb
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Regix (1st October, 2022)
Hello, can anybody help with virgin eeprom of this car.
With originale eeprom not possible coding injectors. eeprom readed with ktag.
Now car start , but rpm only 1500
DTC- P062F engine control unit internal fault .
Thanks. Regards.
Thanks elmaro, its virgin or only crc in my original eeprom?
This is your file with CRC corrected by RENAULT CAN/K-LINE TOOL Attach the original file. I can make you virgin.
The result of checking your file.
[12:07:40] Status : Software Version -> [ 1037390527 ]
[12:07:40] Status : EEPROM Type -> [ 95320 ]
[12:07:40] Status : Number of blocks -> [ 41 ]
[12:07:40]
[12:07:40] +-----------------------------------------+
[12:07:40] | BL # | SIZE | RANGE | CRC | CRC_OK |
[12:07:40] +------+------+-----------+------+--------+
[12:07:40] | 0000 | 003E | 0000-003D | F09A | OK |
[12:07:40] | 0001 | 0002 | 0040-0041 | FEFF | OK |
[12:07:40] | 0002 | 0021 | 0044-0064 | FEFD | OK |
[12:07:40] | 0003 | 002D | 0067-0093 | FA01 | OK |
[12:07:40] | 0004 | 000F | 0096-00A4 | FEFB | OK |
[12:07:40] | 0005 | 0030 | 00A7-00D6 | FE19 | OK |
[12:07:40] | 0006 | 0037 | 00D9-010F | FF79 | OK |
[12:07:40] | 0007 | 0022 | 0112-0133 | F74A | OK |
[12:07:40] | 0008 | 0018 | 0136-014D | FF41 | OK |
[12:07:40] | 0009 | 001E | 0150-016D | FFDF | OK |
[12:07:40] | 000A | 0017 | 0170-0186 | FFF4 | OK |
[12:07:40] | 000B | 0043 | 0189-01CB | FBDA | OK |
[12:07:40] | 000C | 001B | 01CE-01E8 | FE55 | OK |
[12:07:40] | 000C | 001E | 01EB-0208 | FE55 | OK |
[12:07:40] | 000D | 0017 | 020B-0221 | FFD4 | OK |
[12:07:40] | 000E | 001F | 0224-0242 | FFEC | OK |
[12:07:40] | 000F | 007D | 0245-02C1 | FFF0 | OK |
[12:07:40] | 0010 | 00CA | 02C4-038D | F552 | FAIL |
[12:07:40] | 0011 | 00CA | 0390-0459 | F74F | OK |
[12:07:40] | 0012 | 00D8 | 045C-0533 | B77B | OK |
[12:07:40] | 0013 | 00DE | 0536-0613 | C68B | OK |
[12:07:40] | 0014 | 00C4 | 0616-06D9 | F3BC | OK |
[12:07:40] | 0015 | 0064 | 06DC-073F | F482 | OK |
[12:07:40] | 0016 | 0022 | 0742-0763 | FDCA | OK |
[12:07:40] | 0016 | 001E | 0766-0783 | FDCA | OK |
[12:07:41] | 0017 | 0026 | 0786-07AB | FFE8 | OK |
[12:07:41] | 0018 | 0024 | 07AE-07D1 | F9AD | OK |
[12:07:41] | 0019 | 0014 | 07D4-07E7 | FBFA | OK |
[12:07:41] | 001A | 00A3 | 07EA-088C | FF3C | OK |
[12:07:41] | 001B | 0056 | 088F-08E4 | FF70 | OK |
[12:07:41] | 001B | 005E | 08E7-0944 | FF70 | OK |
[12:07:41] | 001C | 0021 | 0947-0967 | FF48 | OK |
[12:07:41] | 001D | 009A | 096A-0A03 | FFE2 | OK |
[12:07:41] | 001E | 001B | 0A06-0A20 | FFE1 | OK |
[12:07:41] | 001F | 0023 | 0A23-0A45 | FB9F | OK |
[12:07:41] | 0020 | 002C | 0A48-0A73 | F7AE | OK |
[12:07:41] | 0021 | 000E | 0A76-0A83 | FF7F | OK |
[12:07:41] | 0022 | 0043 | 0A86-0AC8 | FFD3 | OK |
[12:07:41] | 0023 | 0021 | 0ACB-0AEB | FFDC | OK |
[12:07:41] | 0024 | 004E | 0AEE-0B3B | FCDE | OK |
[12:07:41] | 0025 | 0010 | 0B3E-0B4D | FFDA | OK |
Thanks.
With your CRC , will be possible injectors coding?
if can , please virgin, I try two solution.Regards.
Is this the original file or a modified one? There is no VIN number on it.
I read the eeprom with ktag for the first time when the car arrived.
Hello
Master 2,5 with eeprom 95320
Car don't start
please have look if is good eeprom.
Many thanks
Your file CRC OK
SYROB007 (27th November, 2022)
