Hello - I had same problem with my Hitag2 one time....I changed the USB cable. If you have the type of USB cable where there is a voltage reducer built inline, it won't work. It should be a normal USB cable, nothing fancy.
HI everybody
I baught a HITAG2 V3.1 chinese clone and it worked very fine just one day.I explain my problem
I baught the hardware and I used the soft sold with it HITAG2.V3.1
The next day I tryed to use it and the fallowing message appared : RECONNECT HARDWARE TO USB ( that's what I do )
The hitag reader is recognised all is ok ( no hardware conflict ) I tryed on severals PC whit differents operatig system
and when I click on "HARDWARE INFO" I can see the serial number hardware.I did not use any update software ,only the supplied whit the hardware.I leaved a message to a guy on another forum who baught 1 hitag reader,he has exactly the same problem ,he returned it to his seller who changed it ,worked 2 day and the same problem.
When I make search on the web a lot o people says that these clones does not work!!
Can someone tell me if they found a solution.
Hi thanks for you answer ,I tested it on another pc again and it did'nt work , I tryed again on the first computer and it works fine.Previously I baught hitag2 V3.0 and I used it with v3.1 software and it worked 2 days and since this day always the same message " reconnect hardware to usb" and nothing to do with this interface .
That's why I baught V3.1 hardware +software ,today all is ok .
Can tou tell me if you succefull generate transponder from audi and BMW dump from kessy ?
programmed a cas 2 from dump using the useless clone hitag2 from china and it works fine.
if u make pro job and earn money then buy original, first job i tryed with clone and it did not recognize dg256 eeprom, i used original no problem.
i beleive there is no good clone of hitag2 yet.
Sorry for the late ,just ti says that the problems were the fallowing:
-The pc time date must be 2010
-I used several usb cable and the only one witch worked is the blue one sold with hitag reader
Hi, I have changed date to 2010 and same problem, any other ideas???
Love DK long time too...
Don't forget the button
Hi all, I tried in another computer and nothing, anyone else that can help me???
I have this problem . The Internet has been included. It is necessary full flesh for atmega48. Who can help an full dump ?
someone has a dump from Atmega? for Hitag2 v3.1.
I bought hitage 2 from china v3.1 first time the hitag was working fine wo problem i managed to made transponder for touareg pcf7936 and all done work petfect
The next day the when i opened the software said hardware not recognized pc date time is set to 01/01/2011 like as described on hitag2 user manual when connect usb is recognized as usb serial converter i try to set driver manually fro hitag ibstalation folder but hardware dont recognize those drivers any one could share any solution to get hitag a second life
Regards
Envoy? de mon SM-G920F en utilisant Tapatalk
pitake (25th April, 2018)
For me it worked maybe two weeks and died .... .... xxxRL
I tried to dismantle but he brewed poksidine resin.
Upload pictures later.
Pictures ....
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
keyantic (22nd September, 2015)
Try december 2010
pandora6 (17th September, 2015)
Yes, I already know .... .... '10.05.29
