and I am convinced 99% that it_rohm __256_x_16_bit
A topic that interests me
Bllinda (30th June, 2014)
Thank you for the response.
gepakg (30th June, 2014)
can anyone check if this eeprom will work in my case ...
4 x FM93CS66LM8 (MICROWIRE Bus Interface) 4096-Bit Serial Fairchild SO-8 4pcs | eBay
I have order some
I know what lies_b_r_93_L_66_RF-WE2, we only need to check.
can anyone let me know where i can find the eeprom that i need . Will 93c66 from fiat bcm work ...?
Do not litter theme. Create a new ...
I try with 93c66 from fiat punto bcm and it worked perfectly
THANKS all for your help .
Gapakg file worked perfectly
gepakg (18th July, 2014)
z1000sx flash read.jpgHi to everyone. It is any chance somebody have good eeprom read for kawasaki z1000sx 2011 ecu 21175-0333.
You need to cut one hole in ECU and read eeprom...
only way...
Greetings, can you please help me with immo key adding to dump? The original ecu (21175-0272) got burn after regulator failure, so I barely found new one in Japan with different numbers (21175-0319), accordingly to dealer p\n's should fit to the bike. I have been attached the dump and key reading. Iprog clone says "The key not of this immo" even when I tryed to write new key with it... Thank you.
Good day! I'm new here, please don't kick me too hard. I have a problem with KAWASAKI Z1000 (ECU 21175-0274 112100-7930 TBCF1E ) I went to check to compare the dump in RA66 (IC502). My engine cuts off injection on the second cylinder. So far, I can't figure out why. We came to the conclusion that it is the ECU that does not see the flash in one cylinder and turns off the injection into this cylinder. The motorcycle is in the service, but they cannot determine the exact cause. They nod at the malfunction of the ecu. When checking all four injection and ignition signals, we concluded that the ignition signal is constantly on all 4 cylinders, and the injection signal is on all four for the first two seconds, after which the second injector signal disappears. The resistances of all four channels for the injectors are identical and for the input of the ignition coils are also identical. But one of the four exhaust pipes is cold!
Доброго дня! Я тут у вас новенький прошу сильно не пинать. Имею проблему с KAWASAKI Z1000 (ЭБУ 21175-0274 112100-7930 TBCF1E ) зашел проверить сравнить дамп в RA66 (IC502). У меня двигатель отключает впрыск на втором цилиндре. Пока разобраться и найти причину не могу. Пришли к выводу что именно ЭБУ не видит вспышку в одном цилиндре и отключает впрыск в этот цилиндр. Мотоцикл в сервисе находится но они точно установить причину не могут. Кивают на неисправность ЭБУ. При проверке всех четырех сигналов впрыска и поджига сделали вывод - сигнал поджига есть постоянно на всех 4рех цилиндрах, а сигнал впрыска первые две секунды есть на всех четырех, после чего сигнал второй форсунки пропадает. Сопротивления всех четырех каналов по форсункам идентичные и по входу катушек поджига тоже идентичные. Но одна из четырех выхлопных труб холодная!
I have kawasaki 21175-0272 epprom 93c66
Can someone check if immo is ok or epprom not corrupted because not recognizable with any tool the epprom ?
