i knew this
### How to flash a dm800 via web browser ###
last time i did with same detraction . but this time bad luck
thank you very much mr nibor
mr nibor . can i telnet the image with DCC . if yes . then how
thank you
dont remember 100%, but if you use dreamup you should be able to fix it:
http://www.digital-kaos.co.uk/forums...dreamup-42950/
hello i cant see the files to download and when i want to post new thread i cant find in forum new thread
thank you mr nibor .
i tried with dreamup also when i press connect in the dreamup programmer .after i plug my receiver to power black receiver led . no response.i do not know whats wrong with the receiver or Gemini image is not allow to upgrade other image , but receiver is working fine , with Gemini ,only the problem when i want to change the channel i have to use left+right button , not up+down
is there any siltstone ?? so i can change channels with up down button
thank you
have you enabled/disabled the "dont open serial port"?
it should be disabled to get access
in the receiver or in the computer?
thank you?
i have to learn more about this...
i am newbie..
Thank you for the instructions.
However; finding a pc or a notebook with a serial port is very hard to find these days and with almost all "usb 2 serial" cables not functioning well, i hope an alternative solution can be found sometime soon.
My only solution, until now, is a 15 year old notebook which I hope it doesn't totally break down until another solution is out.
Yeah I know.... I use a USB to RS232 adaptor from DealExtreme: Cool Gadgets at the Right Price - Site-Wide Free Shipping (Page 1) and it works 100%
Then you get a normal Null modem cable connected to the adaptor, and everything works.
I have tried to use a direct USB to serial cable with little luck...
Its sticking on loading enigma likely due to me deleting some thing I shouldnt. Is there a reboot/ recovery ?
Its a year or so since I first flashed the box and setup.
The dreamup guide look good but is it the complete set up that I need to where the dreambox manual take over the instrution.
Ill give it ago after down loading dreamup.
harry
