Results 1 to 11 of 11
    Nov 2010
    Default Dahiatsu Terios 2008 Add key data to immo file please
    hi, need please to add this key data for this immo from a Daihatsu Terios 2008, immo 89780-b4020, eeprom 93c66. all key lost.
    key data from ID 67
    PG1. B2
    PG2. 35
    PG3. C9 BD 3A 16
    DATA STREAM PAG4. 7E 3A BD C9 51 36 C8 12 80 0B
  2. The Following User Says Thank You to llaverosv For This Useful Post:
    mcday (30th March, 2015)
  3. #2
    Feb 2013
    u can add key manual but u must to make ffffff in immo box then turn swetch on 5 time //////////
    Nov 2010
    hi, thanks for answer. FFFFF in all the immo file ?. and then just cycle keys ?, need to do 30 minutes bridge on obd2 ? thanks for your help
    mauricio
    Mar 2011
    You must use 4D ID 67 with pg1 52 .
    To add new key:
    -connect 13 +4 with jumber.
    -insert the working key and Ig on, when you note the security flash.
    -Switch Ig off then remove working key.
    -Insert new key then Ig on, after you note security off.
    -switch Ig off, remove jumber and start your car.
  6. The Following User Says Thank You to fadhle For This Useful Post:
    llaverosv (22nd October, 2014)
  7. #5
    iamfooser's Avatar
    Sep 2012
    Use the attached file.
    Once immo box plugged in, the LED will be solid.
    Insert key with pg1 52, if key is recognise it will blink once and then stay solid.
    Register 2nd key if you want to, if not cycle key 5 times to close registration.
  8. The Following User Says Thank You to iamfooser For This Useful Post:
  9. #6
    Nov 2010
    nice !!!! i?m on my way will let you know
  10. #7
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by llaverosv View Post
    make sure you have the right key
  11. The Following User Says Thank You to gwee For This Useful Post:
  12. #8
    iamfooser's Avatar
    Sep 2012
    <br />
    id 67 key 1 master<br />
    P1: 52<br />
    P2: 4E<br />
    P3: C3 98 0B 04<br />
    P4: A7 0D B0 E6 8B<br />
    <br />
    id 67 key 2<br />
    P1: 52<br />
    P2: 2E<br />
    P3: DF 26 BD 16<br />
    P4: 3B 5D FC B3 3B<br />
    In the event you need the right key data.
  13. The Following User Says Thank You to iamfooser For This Useful Post:
    llaverosv (25th October, 2014)
  14. #9
    Bllinda's Avatar
    May 2010
    Baltic
    How to_record_key again scan_damp.
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  15. #10
    Jul 2010
    Bllinda, u can use iamfooser posted reset file, write the file. Plug in the immo box, immo light will immediately turn ON. Prepare 2 pcs of Daihatsu keys, insert key 1 into ignition, immo light will turn OFF and ON back again. Pull out key 1, insert 2nd key, immo light will be OFF by then. Test the key to start car.
    Note: if you intend to program 1 key only. Insert key and after that turn ignition ON x OFF 5 times. Once immo light goes OFF, you can start the car.
  16. #11
    Nov 2010
    thanks again for your support !!!!
