Results 1 to 8 of 8
Thread: stuck on load
    May 2014
    Default stuck on load
    my f5s box isstuck on load any ideas thanx in advance
    Apr 2012
    Quote Originally Posted by aron1961 View Post
    A little bit more info would be useful.
    When did it go faulty ?
    Updating firmware ?
    Updating Channel List ?
    May 2014
    just had new dish put up conected sat cable turn it on n just stuck on load
    Apr 2012
    What does it do with Sat Cable disconnected ?
    May 2014
    same with n without sat cable ,ive gotta pull the powerlead out to power it dowd ? regards,, box just says load
    May 2014
    Yes I have now got the same problem after updating AJ`s most recent channel list from USB. Everything was working fine prior to this??? I have tried re booting without the satellite cable connected, without the USB connected etc. The only way I can power the box down or up is by removing the power cable ( remote controll doesn`t function) Is there anyway to force the box to boot in a safe mode? At least I could then re install firmware etc if needed?
    Top Poster BrunoJ's Avatar
    Jul 2013
    At Home
    Mar 2013
    it could be a clone had a few clones and they dont like the new ajsat list even after reflashing via rs232 it still the same box got binned and replaced
