Did you getcode as im struggling aswell to g
Et code
Et code
Hi ..please help i lost my long coding VW golf mk6 2012
HW:1K0907379AD
VIN: 3VWG61K99M052428
Vento 2.5
Manual transmission
LHD
Thank you very much for your support and answer
Всем привет, нужна колировка для блока 1K0907376 BD
vin WVWZZZ1KZ9W080548
hello!!!can anybody help mee with long coding for vw scirocco 1.4 tsi 160 cp automatic gearbox vin:wvwzzz13z9v033819 abs hardware nr:1k0907379be. km:386655.thankm
thank you!!!
If I help you, just press Thanks and Reputation please.
hi everyone
i need help witn long coding for ABS for VW Golf 6, 59 kW (80 PS), from 2009
WVWZZZ1KZ9W547304
left hand weel
petrol
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 49243 001 1048576
VCID: 76E353DFC1C73426E1-8022
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BD HW: ÿÿÿÿÿÿÿÿÿÿÿ
Component: CGGA MM4HV G 8326
Revision: --H10--- Serial number:
Coding: 0002031
Shop #: WSC 49913 141 999999
VCID: 61C91083B849A39EA4-8034
VINID: 9E69EAAAA05BA899C51070C0106849DDDF
No fault code found.
Readiness: 0110 0001
MANY THANKS !!!!!!
Did not work...![]()
hallo,
I need help with long coding for Vw Scirocco 2.0tsi ABS/ESP unit. LHD Petrol ABS unit:1K0 907 379 BE
Vin:WVWZZZ13ZBV012771
Adres 03: ABS/hamulce (J104) Plik etykiet:. 1K0-907-379-60EC1F.clb
Oznaczenie elementu SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Komponent: ESP MK60EC1 H31 0108
Weryfikacja: 00H31001
Kodowanie: 00000000000000000000000000000000000000
Kod serwisu: WSC 00241 211 101484
VCID: 76E353DFC1C7343FE5-8022
Thank You!
Try this:
743B40F5492300FC2E1202EB921A0041350800
Remember......This code is calculated with information that you give here. So don't claim that your code is not working. I dont have a time to pray for other info about your cars. It is easy as it is....please post your full VCDS scan for codes or full info about equipment of your cars... Mr. sebva1....this is not about you....or anybody else....it is about me...couple days ago I have a guy which want to adapt ABS long codding in a car where he removed ABS unit at all. He didn't know that he don't have a brakes...
Need long coding for my 2009 EOS.
Friday,18,April,2025,17:59:36:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.0.0
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVWAA71F49V005148 License Plate:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 62 72
VIN: WVWAA71F49V005148 Mileage: 185270km-115121miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 BE HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3289
Revision: AAH03--- Serial number: VWX7Z0H43NQ9DR
Coding: 041C010A18070160
Shop #: WSC 00020 790 00000
VCID: 6ED37BBF79970CE621-803A
VINID: 9E69D1447056109980005044209F53F3F7
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H31 0107
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 36827 005 1048576
VCID: 78FF5DE7CBD34256FB-802C
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 185141 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12288
Count: 195
Count: 45056
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HC HW: 1K0 820 047 HC
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6CD771B74F8BFEF60F-8038
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008495438
Coding: 11848F0340041500470000000F00000000285D035C00012000 0000000000
VCID: 3365AACB5235610E0E-8066
Subsystem 1 - Part No: 1Q1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 260508 022 0501
Coding: 00038805
Shop #: WSC 00020
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 D HW: 1K0 919 475 D
Component: PARKHILFE 005 1406
Revision: 00005000 Serial number: 0 263 004 291
Coding: 101001
VCID: 3365AACB9235610E0E-8066
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 73 Airbag VW8C 0180
Revision: 92010018 Serial number: 003B3003PA8K
Coding: 0014131
VCID: 3A7B87EF755F9046CD-806E
Subsystem 1 - Serial number: 6332SRB4073C469FB
Subsystem 2 - Serial number: 6342SRB407424D2D1
Subsystem 3 - Serial number: 6372URB403068495$
Subsystem 4 - Serial number: 6382URB4030684991
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0000041
VCID: 03053A0B4215118EDE-8056
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Q0 920 864 B HW: 1Q0 920 864 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H43NQ9DR
Coding: 0023303
VCID: 3169A0C3A829531E7C-8064
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 181163 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08609112E
Coding: E9A07F260002025000
VCID: 356194D35C417F3E20-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 D HW: 1Q0 959 255 D
Component: Verdecksteuergeraet 0824
Revision: 0033100M Serial number: 081370197
Coding: 0655366
VCID: 397998E370599B5EC4-806C
1 Fault Found:
02364 - Closing Assistance
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 3
Reset counter: 239
Mileage: 185143 km
Time Indication: 0
Date: 2000.00.00
Time: 01:11:01
Freeze Frame:
Voltage: 10.20 V
Voltage: 10.10 V
Voltage: 4.90 V
Error Code: 0
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 E HW: 1Q0 959 701 E
Component: Tuer-SG 006 1211
Coding: 0001207
VCID: 366393DF4147742629-8062
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A5BB7AF85FF20C6BD-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 93908A800186281B0804040FB0080E0488FCA0
VCID: 71E960C368A9131E3C-8024
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1Q0 959 702 E HW: 1Q0 959 702 E
Coding: 0001206
VCID: 377D9EDB464D8D2E32-8062
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 017 0021
Revision: 00017000 Serial number: VWZ4Z7H6339501
Coding: 0040401
VCID: 204F5587F3C3EA96E3-8074
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 006 1301
Coding: 0000128
Shop #: WSC 00020 790 1012544
VCID: 3467A9D7573B663617-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
End-------------------------(Elapsed Time: 01:56)--------------------------
Your long codding is:
513B6008092200FF8A0C06E890210041700000
Test it and report here.
