Results 1 to 7 of 7
    Default Delete the throttle opel 1.9cdti
    Hello. Needs help to delete the throttle with VECTRA 1.9tdci. Is it possible to work only with the engine off? I turned off the EGR. Regards
    Bulgaria
    You need make it open or totally remove?
    Better still open. I tried to hysteresis EGRoff but not enough. Limpmode after a few minutes.
    Sep 2013
    Belarus
    I have 100% work solution DPF,EGR,Throttle OFF all disconnect
    Bllinda's Avatar
    Baltic
    Post
    Del_saab'e_throttle error and remained connected.
    today
    A topic that interests me
    Sep 2013
    Belarus
    give me dump
    thanx for help. Throttle disconnect. Dtc off
