Results 1 to 15 of 15
    DK Veteran wooper's Avatar
    Sep 2008
    Default Digitv AU update????
    Hello.
    I noticed the magic patch dated 15/07 says fixed digi tv au.
    so when I load the new soft cam, do I need au on or off????
    Sorry am thick but appreciate your advice.
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by wooper View Post
    Hello.
    menu>options>set the digi-tv A/U to on
    and if your useing the latest patch from
    15/7/09 the patch will auto update the keys for you
    you dont need to load the softcam unless you dont want to
    wait a few mins for the key to update. it wont give any probs if you load the softcam
    Please Read Carefully!
    Sep 2008
    Thanks for the prompt reply Benny, as always great help.
    So do I understand right, once I load the new patch (which I did last night), I wont have to load softcams again?????
    Would I then have to load the next patch? what I'm trying to ask is would Digitv be open for a good while???
    Nov 2008
    north west uk
    thats correct mate the latest patch was to fix the digi-tv A/U thats why you need the A/U turned on in the menu options and when there's a key change you just leave it set on a digi-tv chn and the patch will update the key for you. as for how long it will keep updating that depends on the provider, if they make a major change that could knock the patch A/U out and stop it updating, then you need to load the softcam again,there wont be anouther patch untill some thing needs a fix
    or there is something new that the patch can open.
    Sep 2008
    Cheers Benny.
    The keys change that often thses days you loose track where your up to.
    May 2009
    I have a TM3200
    So it doesn't have the AU facility option is that correct
    I have noticed a couple of time when I go to enter Keys before I can enter it updates.
    So as its patched do I just wait for 1W to update itself each time?
    Sep 2008
    am not too up on these things, but have not seen a patch for 3200 with AU fixed.
    Someone will be along in a minute with more knowledge than me.
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    there isnt a working au patch for the 3200 m8
    either enter keys via remote or load latest softcam
    PS3= krazylegz120282
    May 2009
    Strange
    Last night I switched to Digi to enter the keys got called away and when I came back Digi was clear again
    Second time this has happened
    Thats why I thought it was AU
    Either that or I had been at the Gin again
    Colin
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Au is working on 3000init? Im sure of it!
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
  11. #11
    Newbie zerokool's Avatar
    Mar 2009
    London
    Is there a DighTV AU for the TM6800 yet
  12. #12
    Aug 2008
    var/tuxbox/plugins
    No but i can tell you that it will be here soon!
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
  13. #13
    Nov 2008
    north west uk
    the tm 6000 hd boxes have always been the last in line for patches
    it's the same for the clarke-tech 5000hd thats the same spec as the tm 6900
    i often wonder if it's more difficult to make patches for the hd models
    but it's not much trouble to load a softcam
  14. #14
    Jul 2009
    is there a working patch for au digi 1w for the tm5400ci+usb
    ive tried 260509 but get memory error
    thanx
  15. #15
    Oct 2008
    I have the tm5400 and patch working - no problems.
    Tom
