Page 4 of 14 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 197
  1. #46
    Jul 2013
    Scotland. UK
    Did a lost keys Pajero IO Pinin thing the other day. Popped boot lock out first (because it's a 2min job) No code there, but thought I'd look on boot just in case. Dint bother stripping boot lock down tho, just put it back.
    MIT11 Code was as I thought on the drivers door lock. Can't be viewed with a scope thru window rubber from outside, barrel slides inside handle assembly and is completely covered, door card off job.
  2. The Following User Says Thank You to instakeys For This Useful Post:
    muzikisme (9th December, 2015)
  3. #47
    anyone have an idea where the key code for honda accord 2003 is stamped? searched everywhere.
  4. #48
    cjawahir's Avatar
    T&T
  5. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
    eepromRipper (3rd April, 2015), PremierD (31st March, 2015)
  6. #49
    UAE(RAK)
    Honda key codes almost on every lock but hard to see if rusty always start from an alphabet eg: M708
    Lexus 1992-1997 passenger side 4digit code
    1998-2014 passenger side 5digit code if no lock on passenger side then driver side starts with 4 and 8
    Cheve Caprice and Lumina 2001-2006 Via OBD Mechanical code
    Suzuki swift and 2006 onwards on driver side 5digit code starts with 6
  7. The Following 4 Users Say Thank You to usman295 For This Useful Post:
    eepromRipper (3rd April, 2015), Faraday (28th February, 2018), instakeys (2nd April, 2015), lion0304 (2nd October, 2015)
  8. #50
    Hanukkah's Avatar
    Quote Originally Posted by soxten View Post
    Hanukkah: in Cem.
    Christian Johansson via Iphone 5s
    Here is CEM dump... Can you tell me what the mechanical key code is? Thanks
  9. #51
    soxten's Avatar
    Mar 2013
    Send me pm plz
  10. #52
    Hi ...
    This is a list of ford key codes from vin
    VIN >>> KEY CODE + RADIO CODE
    I hope it'll be useful for some of you .
  11. The Following 33 Users Say Thank You to otokeys For This Useful Post:
    armpower (26th June, 2015), Automat (20th April, 2015), branci2008 (2nd April, 2015), brane0001 (30th April, 2023), buga37 (29th April, 2015), buntbart (17th June, 2017), cjawahir (2nd April, 2015), dmp (28th February, 2017), edem46 (20th January, 2017), edubandus (8th January, 2024), gbovs (3rd January, 2017), georgievgoro (26th April, 2023), gojko (13th November, 2019), ilijica (10th May, 2024), kemaster (2nd April, 2015), key mechanic (7th June, 2022), key4man (3rd April, 2015), keyantic (19th April, 2015), line44 (28th October, 2022), lion0304 (2nd October, 2015), lock-key (30th September, 2015), Locksmiths (20th June, 2019), maaxxyy (14th November, 2016), mickye_dj (5th November, 2017), pepi (3rd January, 2017), rm23 (19th April, 2015), sasa5 (8th April, 2017), techterr (3rd June, 2015), triak88 (8th June, 2016), VictorVonDoom (7th September, 2018), vsanyi (9th February, 2017), ybot (7th January, 2016), Zapp (18th September, 2021)
  12. #53
    Quote Originally Posted by otokeys View Post
    Hi ...
    What market?
  13. #54
    Jan 2011
    anyone know were the cut code is on a ford mondeo year 2001
  14. #55
    stalonerambo
    Guest
    hi guys need a code for this one ford, fiesta 2000 , cut are 331412 , f........a ,
  15. #56
    May 2013
    Mazda 2 Drivers Door Lock
  16. #57
    Bllinda's Avatar
    Baltic
    Series Rule:
    Biting trial order is Odd/Even/Odd/Even or Even/Odd/Even/Odd ...
    today
    A topic that interests me
  17. The Following User Says Thank You to Bllinda For This Useful Post:
    muzikisme (10th December, 2015)
  18. #58
    Bllinda's Avatar
    Baltic
    I did not find the desired.
    Ford'00-'02 F T1051-241434
    Quote Originally Posted by stalonerambo View Post
    hi guys need a code for this one ford, fiesta 2000 (mk4)-T2330, cut are 331412 , f........a ,
    P.S. T1457-331412
    today
  19. #59
    for fiat punto i have stamp on lock
    << 153
    1102 >> blade is GT15R
    somebody help me with cutting code ? in didn t find in istacode
  20. #60
    topclef's Avatar
    this is your cutting code ,
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
