Page 5 of 14 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 197
  1. #61
    Jul 2013
    Scotland. UK
    Quote Originally Posted by armpower View Post
    Fiat cars have stamped the key code on ignition lock.Just remove the ignition lock , the code is stamped on the side of lock.
    I'm going to have a go at this today on a 2004 Punto.
    I can't find my GT15 Lishi anywhere - whats the best way to extract the barrel from this?
  2. #62
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by instakeys View Post
    I can't find my SIP22 Lishi anywhere - whats the best way to extract the barrel from this?
    When the trunk lock is in good condition it is also good to make a key from it. Just 2 screws holding the lock and then, there is only 1 pin need to be removed and the plug comes out with key code stamped.
    EDIT: In good condition I meant if customer is sure the key worked also in this lock.
  3. The Following 2 Users Say Thank You to p1et For This Useful Post:
    Faraday (7th January, 2017), instakeys (23rd September, 2015)
  4. #63
    Jul 2013
    Scotland. UK
    Thanks p1et. Useful information!
  5. #64
    Wirral
    Quote Originally Posted by p1et View Post
    dont waste your time boys, most of these puntos, open passanger door, you will see an airbag lock. pops out in 5 seconds. All cuts are inside, and number printed on barrel. 2 min job.
  6. The Following 17 Users Say Thank You to parapilot For This Useful Post:
    Automat (28th September, 2015), bawareca (23rd January, 2017), Cesarec (30th September, 2016), didi_du_93000 (24th September, 2015), Faraday (28th February, 2018), gojko (13th November, 2019), gtmech (25th September, 2015), igorr (24th September, 2015), instakeys (23rd September, 2015), Johnner (23rd September, 2015), key4man (26th September, 2015), obdsystems (23rd September, 2015), p1et (24th September, 2015), paul_12345 (25th September, 2015), Recoder (24th September, 2015), smokey08 (25th March, 2018), totalkey (23rd September, 2015)
  7. #65
    Jul 2013
    Scotland. UK
    I'll test this mate. Good tip. Sounds faster than picking and decoding...
    I'll post some pics to help others when I finally get back to the car.
  8. The Following User Says Thank You to instakeys For This Useful Post:
  9. #66
    Jul 2013
    Scotland. UK
    Good info there! I can't believe I did not know this?!?
    GT15 key code stamped on barrel of airbag lock, 10 seconds to remove.
  10. The Following 19 Users Say Thank You to instakeys For This Useful Post:
    Automat (28th September, 2015), bigkey (8th November, 2015), canakbas (2nd July, 2018), cqae (29th September, 2015), didi_du_93000 (24th September, 2015), ExpressSSD (6th June, 2021), gojko (13th November, 2019), gtmech (25th September, 2015), IanBMW (21st May, 2021), IKEYS (21st January, 2017), key4man (26th September, 2015), p1et (24th September, 2015), parapilot (24th September, 2015), paul_12345 (25th September, 2015), purdy (7th January, 2017), Recoder (24th September, 2015), rojhat (22nd October, 2018), super jumbe (24th February, 2019), vickypb39 (30th December, 2015)
  11. #67
    Amazing, maybe good for grande punto?
    Sent from my VOYAGER2_DG310 using Tapatalk
  12. #68
    Jul 2013
    Scotland. UK
    I think in future I'll try this on most Fiat/Alfa etc and post pics of what I find. Very good info this!
  13. The Following 2 Users Say Thank You to instakeys For This Useful Post:
    Automat (28th September, 2015), p1et (24th September, 2015)
  14. #69
    On vw golf mk3 y 1994 , stmped on drivers side lock
  15. The Following 3 Users Say Thank You to ArnautuIonut For This Useful Post:
    Automat (28th September, 2015), instakeys (24th September, 2015), key mechanic (7th June, 2022)
  16. #70
    Bllinda's Avatar
    Baltic
    Default Fiat'04
    instakeys
    How this is done within 10 seconds with a paper clip?
    today
    A topic that interests me
  17. #71
    kemaster's Avatar
    BG
    Quote Originally Posted by Bllinda View Post
    instakeys
    If you mean what is seen in his hand on picture- I don't think it's paper clip . This might be the retaining clip that holds the plug
  18. #72
    Jul 2013
    Scotland. UK
    Quote Originally Posted by kemaster View Post
    Flathead screwdriver removes the lot from the dash with a gentle pry...
    Pop the metal clip out that kemaster pictured with same flathead - barrel falls out. 10 seconds! Dead simple.
  19. The Following 3 Users Say Thank You to instakeys For This Useful Post:
    Automat (28th September, 2015), mickye_dj (5th November, 2017), p1et (7th October, 2017)
  20. #73
    but does the plug pull out without having the key in?
  21. #74
    Wirral
    Yes mate it will.
  22. The Following 5 Users Say Thank You to parapilot For This Useful Post:
    Automat (28th September, 2015), cjawahir (26th September, 2015), instakeys (30th September, 2015), mickye_dj (5th November, 2017), paul_12345 (25th September, 2015)
  23. #75
    Bllinda's Avatar
    Baltic
    With such could only Curtain can open. Bitting reach .... or is it not necessary ...
    Quote Originally Posted by paul_12345 View Post
    today
