Results 1 to 12 of 12
    furnata's Avatar
    Feb 2010
    Bulgaria
    Default I will give some effort to DIY make synchro Etacs and ECU Mitsubishi Colt
    So after many try's i get the decision
    All you need when you lost synchro between Etacs and ECU is to read (only eeprom is enough)9s12dg128 from etacs and 24c04 from ECU
    Then open files with Hex workshop and see when is synchro lokated ( will post pics) in 9s12dg128
    and write it in 24c04
    In 9s12dg128 synchro is in 1a06 to 1a0c - 7 bytes
    in 24c04 when the synchro is lost you'll get 77 77 77 77 77 77 77 41 in row's 170 and 180
    so you'll need to write synchro from 9s12df128 in this two row's
    You write this 7 bytes and the eith byte is checksumm (you need to calculate)
    example:
    synchro from 9s12dg128 - 6b ad 70 98 84 76 44
    calculate cks. is 61
    so you'll need to write in 24c04 6b ad 70 98 84 76 44 61
    Then you'll nedd to calculate cks from all file and put in the very last 4 bytes in 24c04
    That is without using MUT 3 and other equipment
    Im here to help and to be helped
  2. The Following 22 Users Say Thank You to furnata For This Useful Post:
    armpower (10th September, 2017), auto80 (7th March, 2015), badenaleks (6th March, 2015), bearheroes (6th March, 2015), bram380 (8th May, 2015), caliskan71 (31st October, 2015), ecufix (8th March, 2018), F-1 (22nd February, 2016), fadhle (7th March, 2015), heyalter (1st December, 2017), key4man (7th March, 2015), labase (6th March, 2015), large12390 (27th July, 2017), Manmart (22nd November, 2015), mecadriano (3rd March, 2024), mexanico1971 (28th February, 2020), mihaiservice (6th March, 2015), OFFIMO (6th March, 2015), pinotec (1st February, 2021), radsky (13th July, 2016), stefaudio (8th May, 2015), ucokseparoh (15th July, 2017)
  3. #2
    Mar 2010
    WW
    how calculate cks file ?
    furnata's Avatar
    Feb 2010
    Bulgaria
    with hex workshop mate- simple
    Rerouter's Avatar
    Jul 2014
    Australia
    Custom CRC32 with default poly and different xor and initial?
    A file for feedback, This is all that is asked on this site, Did it work? what value appeared on the dash? maybe some photos or a power-up,
  6. #5
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    Checksum 8bit:
  7. #6
    Mar 2010
    WW
    this is easy, for entire file is necesari
  8. #7
    bearheroes's Avatar
    Dec 2011
    Did any other guy found way to calculate chcksum for entire file? Maybe my brain is not too good...!
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  9. The Following User Says Thank You to bearheroes For This Useful Post:
    heyalter (7th March, 2018)
  10. #8
    Senior Member cdex's Avatar
    Oct 2012
    somewhere beyond the moon
    hello
    i think chksum is - 5E
  11. #9
    Bllinda's Avatar
    May 2010
    Baltic
    Quote Originally Posted by furnata View Post
    example:
    You are wrong .... written somewhere that it is 61
    Quote Originally Posted by cdex View Post
    hello
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  12. #10
    Jul 2009
    I tried all known polynomials and methods but cant get you repaired crc32 75951F8C from file.
  13. #11
    Jul 2009
    no one else has an idea?
  14. The Following User Says Thank You to cammy25 For This Useful Post:
    heyalter (6th March, 2018)
  15. #12
    Nov 2009
    Germany
    syncro CRC-32
    Solution is you have to calculate with CRC32/BZIP2......look here http://www.digital-kaos.co.uk/forums...=1#post3231989
