Results 1 to 15 of 15
    Default Mercedes Atego key programming.
    Please help i have read 93C86 and generated a key and recorded in a T5 with Zed-Bull, but does not start the truck, immo light flashes.
    Can someone help me to see if this good or generate another good key.
    Thanks in advance.
    dumm y key.rar
    KILL_THE_IMMO's Avatar
    spain
    USE A VIRGIN CHIP
    --------HELP OTHER TO BE HELPED--------------
    hello KILL_THE_IMMO.
    I used a virgin and recorded with T5, Zed-Bull.
    but it does not work.
    The chip writes me well FF81A48026106F41
    Anyone know what might be happening,
    a greeting.
    kemaster's Avatar
    BG
    Could be low quality transponder. Did you try another one? Take it out from the key and put it near the antenna coil to test
    I tried it in the Zed-Bull, and reads it well, and I've also tried with another chip, and does not start and immo light flashes.
    The truck was lost all keys, halgien know how it started.
    a greeting.
    kemaster's Avatar
    BG
    Sorry, may be missunderstanding. I meaned to take it out of key and put it near the truck antenna(not zed bull)
    Quote Originally Posted by kemaster View Post
    hello
    I put it in the zed bull and the truck.
    The key've made with 93C86 eeprom of ecu.
    And I made the chip with zed bull, but does not start and if not, if someone can prove it.
    Bllinda's Avatar
    Baltic
    The key is correct.
    T5 ceramic or glass?
    there is a second key. PM
    Quote Originally Posted by luiscarlo View Post
    hello
    today
    A topic that interests me
    hello. Bllinda
    T5 ceramic???
    Bllinda's Avatar
    Baltic
    Yes, you are right.
    hello. Bllinda
    T5 ceramic???
    today
    Sep 2010
    hi
    t5 use gambit or tango
    Hello. abrhem
    zed bull's bad record T5 ???
  13. #13
    Sofia, Bulgaria
    On the PLD board are two 93c86, one with key data, second for other data recording. Are you sure you got right eeprom with key data?
  14. #14
    hello ovitanov.
    It is this that I have checked,???
  15. #15
    Bllinda's Avatar
    Baltic
    It can not be that all is well and the car does not start.
    Look for another good e.cu.
    with any failure, the car?
    what block numesris (A ....)?
    today
